Question about Texas Instruments TI-83 Plus Calculator
All batteries, including the back up have been replaced but I still get the "low battery" notation and the calc. shuts down intermittently.
  • Texas Instru... Master
  • 8,064 Answers
The OS may be corrupted. You should take a look at this article from the TI Knowledge base.
Hope it helps.
Posted on Oct 30, 2009
EL9300 not responding after a battery change. Only a down arrow is displayed on screen on top of screen
Just had this EXACT problem on a Sharp EL-9200C. I got the down arrow to go away and then the calculator functioned like normal. Here's how: I got a ball point pen and rapidly activated the reset button on the back, then rapidly pressing the CL key... probably about 45-50 times, but eventually it cleared all the memory out and the calc was able to boot up. This was after replacing the batteries multiple times and trying every key and every 2ndF key. I feel like the master of the universe now!
Mar 07, 2015 | Sharp El-9200c Scientific Graphing...
2000 volvo s80 electrical shuts off while driving
Your issue is a relay under the hood in that fuse panel regards Chris
Mar 04, 2017 | 2000 Volvo S80
The 670 garmin shut down then say's low battery
musicman340,
It sounds like the rechargeable battery inside your gps is coming to the end of its life. After enduring the temperature extremes of your car in addition to numerous charges and discharges, these batteries do eventually die after a couple years. How old is your nuvi? If this is the problem, the good news is that you don't have to throw your gps away as this battery is readily replaceable if you follow the steps in this video:
The company that produced the video sells a kit which includes the battery and tools necessary to replace your battery. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+670&Show=ExtInfo
I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi is back up and running smoothly.
Mar 15, 2010 | Garmin Nuvi 760 Car GPS Receiver
UPS shuts off intermittently and beeps
More than likely it just needs a new battery. If the power is sagging (called a brownout) the UPS is trying to switch over to the battery to keep the power consistent. The beeping is probably a code that indicates there is an issue with low voltage on the battery. New batteries are around $20-25. Here's a link to the replacement battery: http://batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Hope that helps.
Jan 21, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Battery power trouble
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jan 03, 2009 | Garmin GPSMAP 295 GPS Receiver
TI 84 Plus Silver Edition Wont Work
I tried blowing compressed air with a computer air duster into the I/O port. I do not know what this does but, it REALLY WORKS!!! My daughters TI-84 Plus Silver Edition is working fine.
Feb 08, 2008 | Texas Instruments TI-84 Plus Silver...
Nikon D40 Error Message
Get the kit changed. That should not happen right out of the box, but make double sure the next time around, you charge the battery completely before using it the first time. Not doing this can cause problems.
Nov 18, 2007 | Nikon D40x Digital Camera
Texas Instruments TI-83 Plus Calculator Logo
155 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
