Question about Ricoh IS 450DE VRS Flatbed Scanner
Adf does not scan all pages
I have a Ricoh IS450DE with ADF attached directly to my machine via SCSI. No matter how many pages I have in the ADF it only scans 2 then stops. I am using the TWAIN software that comes with the scanner.
  • 490 Answers
Try cleaning the rubber rollers in the ADF
S. Mohan
Posted on Sep 29, 2009
Paper jaming in ricoh af 1022 in adf
Paper jams in Ricoh Adfs ( or others), generally have origin in dirty rubber rollers. Oh yes, they can look clean but try to wash them with Benzine and check the cloth! You have to have full traction between the rubber and the paper , otherwise they skew and jam or are not picked up even. Other problem is in the exit (lower ADF side) , a misalignement between adf and the machine body. This can be solved with the mounting screws in the Adf back. Dont forget to have the paper format sensors (top right of ADF) clean and last, you may want to check the horse shoe sensors INSIDE (rear cover ADF). In my lifetime as a Ricoh tech, it only happens this once, and because the machine suffered ADF damage due to Portuguese bumpy roads, Ahahah. I am excluding the obvious, such a paper clip, a stapple, a coin , etc.. This happens very often...
Feb 22, 2014 | Office Equipment & Supplies
I have a Ricoh sp c222sf multifunction machine. I'm running Windows 7. I loaded a driver for both the printer and the scanner from thier website. All seemed well until I went to scan from the ADF. It...
u got to unscrew the scanner a bit and arange the adf left or right depending your line position. the adf is not positioned perfect on the machine , and at the end it scan the adf back , thath is the line come from on your scanned document
Feb 02, 2011 | Ricoh Aficio SP C222SF All-In-One Laser...
My Canon MF4150 multifunction device started displaying streaks (or black vertical lines) on pages scanned via the ADF. These streaks appear when scanning from Windows 7 (64bit home premium) as well as...
Hello I just figuered out this problem. When the paper is feed thru the ADF ( Automatic Document Feeder ) there is a plastic piece with a plastic film. Check to see if #1 that plastic film is clean and #2 That the Film is not bent and created a crease which is the line that shows when try to print or scan using the ADF. Hope this helps
Dec 28, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Ricoh 1027 ADF grabs multiple pages causing adf jam
you need to replace the lower of 3 rollers in the ADF (sep roller), for a temp fix you can clean this roller with wd40 as it will soften the rubber and get it to "grip". these rollers (lower of three) are always the first to go "bald on any mnf copier in the ADF and Drawers causing multiple feeding. they are used to allow one page at a time as they either turn backwards or offer torque (resistance) to lower pages
Aug 04, 2009 | Office Equipment & Supplies
Aficio 2015 ADF not working
if you plug the ADF connector while the machine is on the code will appear when you connect the ADF shut down the machine and then connect the ADF plug
Jun 22, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio MP 2000 ADF (auto document feeder) is not working
tape is on the underside of the ADF causing a sensor to not tell the machine that the ADF is in the lowered position. look under where the hinge area goodluck
Apr 22, 2009 | Ricoh Office Equipment & Supplies
Only scans one page ata a time it says it can't recognize paper for ADF
The bulb has nothing to do with the paper feeder.
Open the door and ther has three or to tires or rubbers so clean them with glass cleaner or 98% alcohol if after that dose not feed again you should replace the feed rubbers
Aug 23, 2008 | Ricoh IS450DE Flatbed Scanner
ADF not working for TWAIN APIs
I need a little more description. Does the ADF handles the first page, or no page at all? Keep in mind that Samsung designs its own scanning application (SmartThru). Also check that the connection (parallel or USB) is correctly configured on your app.
Dec 20, 2006 | Samsung SCX-5115 Fax Machines
Ricoh IS 450DE VRS Flatbed Scanner Logo
161 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
