Question about Bosch WAS24460UC Front Load Washer
Bosch was24460uc: delivery guys did not remove shipping pins. we washed a load and there was terrible noise and walking. tech guy removed pins and problems are better but there is still a lot, a lot of noise and banging. did washing with shipping pins damage the machine?
    Genius:
  • Bosch Master
  • 1,460 Answers
Ther could be possible drum suspension unit damage..
Posted on Sep 29, 2009
My brand new Maytag MVWX500XWO is only two days old. I did three loads of ordinary laundry, clothes, socks, shirts, +2 bath towels, and the machine has excessive shaking during the high spin cycle that...
Check to make sure the delivery guy removed the "shipping bolts". If they are removed, then I would call the store about the warranty on the machine.
Jan 05, 2011 | Maytag Washing Machines
Terrible noise when draining
Possibly more hair pins in the pump or possible the pump is faulty check that the propellor is not loose if so a new pump is needed.
Apr 06, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Spin out of control, walks, screams and pounds the floor
Not easy to diagnose as lots of variables to consider, but looking at it logically, it seems that there is no speed control. 2 things responsible for this. 1)Your electronic board. 2) The sensor connected to the motor. Most of the time it is the sensor. Tilt the machine careful sideways until motor is in full view. At the back of the motor, there should be a module attached to the motor.Remove a little cover to allow access to a round magnet. this magnet very possibly has moved. Carefully position the magnet into place correctly then replace cover. Retry wash. Board is expensive so after that, let the technician diagnose and rectify.
Sep 27, 2009 | Bosch WAS24460UC Front Load Washer
My Frigidaire Washer likes to walk around the laundry room while doing the spin cycle. It hasn't always done this. I had a repair guy over who checked out all the springs and everything and ended up...
Is this a front load? Check to make SURE that the shipping pins were removed completely. Thay can sometimes look as if they are and one has broken off(top-load)
Sep 13, 2009 | Frigidaire Washing Machines
I have a WAS24460UC Bosch washer. It won't drain. The pump runs, sounds like it has an air pocket or like the pump is running backwards? I have had a F34 and an F18 erro code.
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hoses from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Sep 10, 2009 | Bosch WAS24460UC Front Load Washer
Our new front load washing machine "walks"
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 04, 2009 | Kenmore Washing Machines
Dancing washing machine
if its real new as in you just installed it look behind hte unit for shipping braces that haven been removed.. they keep the machine solid in shipping and reek havok if not uninstalled
Mar 17, 2008 | Whirlpool AWM6100 Front Load Washer
Bosch model 3301
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. The exit hose should be at about 3 feet from ground level; pump pumps out over this height.
Rate me pl.....if helped.
Dec 03, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WAS24460UC Front Load Washer Logo
223 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
