One of my children threw it off a bed and the screen has moved and now a section of the screen is not working... Vertical lines in 3 colours, first white then rainbow then black.
  • 189 Answers
HELLO
I'm puzzled! Is this a DVD or CD machine? Either way it was not a good idea for your kids to chuck it!! However.....
If it is a DVD player with LCD screen - then the screen is gone! If it is a CD player - the LCD track/time display is gone!
CD player: It may be possible to have the display replaced depending on the make/model and age. It may not be cheap to do.
DVD Player: It will cost you more than a new one to have the screen replaced.
I advise that if you get a new one, keep it well away from your kids (:-).
Posted on Sep 29, 2009
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Hi, my samsung 29 inches got some horizontal line at a above of the screen. The line came out with 3 different colours. Can u show me how to remove it?
Smoothing capacitors to the vertical output section voltage should be checked. Replace them. Check this site for more details.
Jan 29, 2013 | Samsung CW29M64NS 29" TV
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
46 people viewed this question
 Grubhead
Grubhead
