Heat/ac problems after new thermostat install
Changing thermostats from intertherm to a hunter can't get the heat to run air will run however
  • ericmccarson Sep 29, 2009
    I think there is something wired incorrectly with the new thermostat I put the old stat back up and the heat will run and ac runs however the heat won't run with the new stat. there is a wire that was not listed in the diagram for the new stat on the old one it's mark x and is a blue wire do you know what this is?
    are we talking about heat pumps or something else here
    President:
  • 2,923 Answers
Sometimes it gets corroded or clogged from years of coolant buildup. Have you checked the controls? When you change from cold to heat, does it feel very loose when you move it?
You need to check if the control is loose, you might need to change the control, check if there's a fuse that you need to replace and check the heater pipe to see if it's leaking.
Let me know what you would find.
Have a great day!
Posted on Sep 29, 2009
  • Melvin Ramos
    Melvin Ramos Sep 29, 2009
    The Blue wire should be connected to the gas valve. You need to check if you A/C-heater has a gas valve. If it has, then you need to connect that Blue wire to the gas valve.
    You have to make sure that the wiring is correct. Please let me know what you have in your heater.
    Thank you!
  • Melvin Ramos
    I'm sorry, not the heater pump, but the gas valve. Check if you have a gas valve.
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
Furnance not heating
Make sure that the thermostat is set for the proper medium that you are using being gas or electric. Inside the cover of the thermostat should be a setting for either eletrical heat or gas heat. Set this switch for what your system is G for gas or E for eletric. This may solve your problem. Good Luck hope this helped you some
Dave
Oct 26, 2009 | Intertherm P3RA-036K Air Conditioner
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Air and heat have both been running on Hunter 44155C
There should be a switch on the thermostat.
AC-OFF-HEAT
And another switch
FAN ON-OFF-AUTO
Normally, you just set it for heat or AC and set the fan for auto. If it isn't wired correctly, the switches won't make any difference. It will either run all of the time or not at all.
Feb 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Intertherm Thermostat
the wire that is on the x- terminal  on the old tstat will be c-terminal on the new tstat.
Oct 26, 2008 | Heating & Cooling
Programmable Thermostat Model 43157
On my Hunter model, there is a "Span" setting that allows you to change how long the AC/Heat will run before it turns off. Basically, it sets the acceptable range (above and below) your temperature setting. To access this press both the up and down arrows and hold them. "Span" should show up with a number (1,2, or 3). For your problem, change the setting to 1 so the AC will run shorter, and more frequently to keep the temperature more constant.
Aug 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Intertherm Heating and Cooling
I would say that you have ether a wiring problem or a faulty thermostat. The thermostat brings on the A/C through the Y terminal on your thermostat. The heating is brought on by the W terminal on the thermostat. If the wire for the A/C is shorting to the wire for the heating it would give the problem you are describing.
Jul 21, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
