Question about GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side Refrigerator with External Controls and Dispenser
My GE Model #GSS25WSTSS does not dispense ice from the icemaker. I ordered a replacement part through Lowe's Parts and Accessories division but can't figure out how to take the auger-turn part off the motor casing. It's shaped like a U and turns the auger to release ice from the tray through the door. The part spins freely and will not tigthen on the the threaded arm. Any ideas?
  • 31 Answers
You are going to have to bend it to fit,
Posted on Sep 29, 2009
I have major ice build up in the freezer near the icemaker area of my GE side by side. Replaced the icemaker, but the problem came right back. HELP!
Icemaker inlet water valve may need replacing. If the valve
is not closing all the way it will leak water into ice tray.
Sometimes well water without a conditioner can cause
cause this problem. LynnMBent
Oct 27, 2015 | GE Refrigerators
Ge gss22 where is the ice maker supply valve
Pull the refrigerator out and follow the water line to the back. It will go to a double valve solenoid. One half is for your water dispenser, the other for the ice maker. It is possible that this solenoid has failed. You can order the part online and replace it pretty cheaply. Just remember to turn off the water supply (usually under the sink) and unplug the refrigerator before hand and have a towel ready to catch water that will drain from the lines.
To order the new part get the full model number of your refrigerator and go to the GE website and look up their replacement parts page. You should be able to search for that model and all of its related replacement parts there.
Mar 08, 2012 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Ice maker dispenser gets stuck. auger will not turn in the ice bucket. motor that drives auger tries to turn, but something in the front of of the auger/dispenser prevents it from turning.
I have this identical unit and have had this identical problem. What we do is remove the entire ice container from the refrigerator and shake it to break up the ice inside or we remove large chunks of adjoined 'cubes' and replace the entire tray/container and it has worked fine for us thereafter.
Feb 02, 2011 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
Water not dispensing
Most likely your water control valve on rear of refrigerator has failed. Do this pour tap water into the ice maker make sure it is on and let the water freeze. If the ice drops and does not refill then the water control valve is the problem. If ice maker does not cycle then it is the ice maker. Find your model number around the door frame and tell me which model GE you have and I will tell you the replacement parts. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | GE Refrigerators
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
ICEMAKER LEAK ON GE TFX25VR
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 27, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water from ice makers leaks and builds up in botom of freezer
ice maker leaks are usually a sign of icemaker mold corrosion eating the lining off the icemaker causing it to leak. the only repair is to replace the complete icemaker. you will need a complete model number from the unit and the part can be ordered online thru whirlpool or some of the other appliance parts sites. you may even have a local parts warehouse where you live. hopw that helps peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water line to water dispenser is freezing up inside the freezer
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Dec 27, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerators Logo
334 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
