Question about HP PhotoSmart C4280 Laser Printer
When scanning the printer tells me the USB is not connected yet i can still print from the computer.
Maanita
  • 1142 Answers
SOURCE: Can't scan on HP Photosmart C4380 even tho printing works fine
Try scanning without HP imaging software
HP Photosmart C4380 Direct Scan button doesnt function in VISTA
Use the built-in feature of the Windows operating system, called Windows Image Acquisition (WIA), instead of the HP software to scan. Follow these steps to perform a WIA scan.
  1. Make sure that the product is on and that the cable is correctly connected.
  2. Click Start , and then click Control Panel .
  3. Click Printers and Other hardware , and then click Scanners and Cameras .
  4. Look for an icon representing the product, and then review the following information for further instructions:
  5. Double-click the icon to start the Scanner and Camera Wizard . Follow the on-screen instructions to scan images or documents to the computer
  6. If the WIA scan was successful , use the Scanner and Camera Wizard to scan instead of the HP software. To use the HP software, continue to the next step to continue troubleshooting. However, it is not necessary to do so.
  7. If the WIA scan was unsuccessful , continue to the next solution.
  8. Fully uninstall and reinstall the HP software Follow these steps to completely uninstall and then reinstall the HP software. Step one: Uninstall the software Use one of the following methods to uninstall the software. Method one: Uninstall the software using the product CD If the product software CD is available, follow these steps to uninstall the software. Otherwise, skip to the next method.
    1. Insert the software CD into the CD-ROM drive on the computer.
    2. If the Welcome installation screen appears, click Exit to close it.
    3. On the Windows task bar, click Start , and then click Run (c01463550.gif ). The Run dialog box appears. Figure 4: The Run dialog box c01463551.gif
    4. Click Browse . The Browse window appears.
    5. Navigate to the CD-ROM drive that the software CD is in, and then double-click the drive.
    6. From the list of folders and files on the CD, double-click the Util folder.
    7. From the list of folders and files inside the Util folder, double-click the CCC folder.
    8. From the list of folders and files inside the CCC folder, double-click the Uninstall_L3.bat file or Uninstall_L3_64.bat if a 64-bit operating system is installed on the computer. The Browse dialog box closes, and the path to the Uninstall _L3.bat file appears in the Run dialog box. Figure 5: Uninstall file path in the Run dialog box c01463552.gif
    9. Click OK . The software uninstaller opens in a command prompt window.
    10. Press Enter to begin the uninstall.
    Method two: Download and uninstall the software If the software CD is not available, follow these steps to download the software and then uninstall it.
    1. Click here to go to the Software & Driver download page on the HP Web site .
    2. Type the product number in the search field, and then click Submit (c01425574.gif ).
    3. If necessary, click the link for the product model number.
    4. Click the correct operating system.
    5. In the Driver section, click HP Full Feature software/driver , and then click Download only .
    6. When the File Download - Security Warning dialog box appears, click Save .
    7. Save the file in a location that is easy to remember.
    8. When the file finishes downloading, double-click the file to extract it.
    9. Click Exit on the Welcome installation screen.
    10. On the Windows task bar, click Start , and then click Search (c01463553.gif ). The Search Results window appears.
    11. In the Search Results window, click All files and folders .
    12. Click More advanced options , and then select Search hidden files and folders .
    13. In the All or part of the file name: box, type Uninstall_L3 , and then click Search . When the search is complete, the file appears in the Search Results window.
    14. Double-click the Uninstall_L3 file, and then follow the on-screen instructions to complete the uninstall.
Posted on Oct 25, 2008
SOURCE: hp all in one says USB IS NOT CONNECTED when I try to scan
my hp c4380 won't scan gives out a error message the usb is not connected but it is.
Posted on Dec 12, 2008
michael_grey
  • 365 Answers
SOURCE: HP Printer C4280 says "USB not connected"
Install software that is twain compliant.
Maybe the HP bundle that came with the printer.
Also Paint Shop Pro,Adobe Acrobat.Photoshop etc.
Use the usb cable after the install of the HP drivers then you may change the default location of where scans are saved.
Posted on Jul 21, 2009
SOURCE: Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: C4200 - says USB not connected when trying to scan
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
Posted on Oct 15, 2009
When i scan to computer it cannot download the application
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 26, 2012 | Lexmark X5650 ALL-IN-ONE PRINTER
Lexmark x5650 cannot retrieve application list
  4. Reboot computer.
Jan 16, 2012 | Lexmark X5650 All-in-One InkJet Printer
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do i get my Lexmark X2350 Printer to send e-mail? I scan my documents, but the new e-mail box does not appear after the scan like its suppose to.
Make sure that your default email program is correctly set on your computer.
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document to verify that the problem is fixed.
Nov 08, 2011 | Lexmark X2350 All-In-One InkJet Printer
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
My printer will print but when I try to scan a document it tells me that the usb cord is not connected. The usb is connected to both the computer and printer. What do I do?
try another printer cable , if same problem remove the program of printer and re- install it again, follow direction one by one, dont make a shortcut
Jul 11, 2010 | HP Photosmart C4280 All-in-One InkJet...
My printer will print and copy but won't scan. It
First, do you have the full-featured version of the software installed (installed on the computer before connecting the printer to the computer)? Second, do you have the all-in-one connected to a print server or USB hub? These can block the two-way communication needed for scanning. Try a direct connection. Also try a new USB cable and a different USB port (if you have any signal loss issues, it matters more with the scanner).
I hope this helps.
Mar 22, 2010 | HP PhotoSmart C4280 Laser Printer
How to scan soemthing onto a computer
Do you have the full-featured software driver installed? (Installed before connecting the printer to the computer.) Then you have the option of initiating the scan from the computer or the buttons on the unit. (The HP Digital Imaging Monitor Windows System icon should be in your system tray. If the program has been closed, restart the HP Image Zone software or reboot the computer.) There is a Start Scan button on the printer which should launch the HP software. Alternatively, start the Image Zone software and there should an option to start the scan.
These directions will only work if the computer and printer are both on and communicating with each other. If you get an error, try a new USB cable and try using a different USB port. If using a USB hub, try connecting to the computer directly. (If using a print server, try a direct connection. Check if the print server supports bi-directional communication; many only support the print functions not the scan options.)
I hope this helps.
Mar 22, 2010 | HP PSC 1510v All-In-One InkJet Printer
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
HP connection trouble
a connection without a driver isn't complete go to www.hp.com select the product , search for the drivers and than it will by BOG not only bong but also scan and print
May 02, 2008 | Office Equipment & Supplies
HP PhotoSmart C4280 Laser Printer Logo
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
