Question about Asko D3122XLW / D3122XLB Dishwasher
Discharge pump on asko d3122 runs continuously. Can only be stopped by turning power off to machine
5 Suggested Answers
  • 28 Answers
SOURCE: ASKO D3122 PUMP STAYS ON AND MACHINE WILL NOT SWITCH ON
The machine has activated a safty seq. There is most likely water on the lower buttom. Leakage or drain pipe blocked. The power will get to the drain pump, when this happends. To prevent overflow on your kitchen floor. Dry out the water. Then it will start as usual.
Posted on Jul 27, 2009
SOURCE: ASKP 3110 - drain pump continuously running
If water gets onto the pan under the dishwasher, there is a styrofoam float that rises and hits a microswitch that causes the dishwasher to drain constantly so that you don't get a flood in your kitchen. Mine has done this when I splashed out water from a bowl that had overturned during the wash and was full of water and when I had some water deposits built up on the door seal that let water through. Sometimes the foat will hang up and I have to wiggle it around to get it to fall back down.
Posted on Dec 27, 2010
SOURCE: The pump on our Asko
d3122 Asko Dishwasher fault code F2 - how do you stop pump runing and reset?
Posted on Jan 05, 2011
SOURCE: Hi, we have an Asko D3122 dish washer, pump runs
Amazing coincidence: same thing happed to us tonight: same day as yours. Good luck to both of us. Rob&Cheryl
Posted on Jan 21, 2011
Asko D3122 WAX MOTOR
Can plug in either way. If was meant only one way, the plug would have a blocking protrusion on one side. Plus the motor will run only one direction no matter which side is the hot side of the wires. As long as is getting power, it will work.
Nov 11, 2014 | Asko D3122XLSS Stainless Steel Dishwasher
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
Dead circulation pump capacitor: I have an Asko
Capacitor should have a uF and voltage rating stamped on it. They are NOT a one-size-fits-all.
Always keep your Owners Manuals so you can use it to get parts. Without seeing it myself, the part will probably have to be replaced.
Sometimes you can find the manufacturer online and get parts through their website.
Possibly find this capacitor at an AC shop.
Oct 29, 2013 | Dishwashers
D 3100 continues to pump out. Program stops and program button flashes
We have just fixed our Asko 3100 dishwasher. You need to undo the screws attaching the unit to the side cabinets. Pull dishwasher out and tilt forward to drain. Put towels down as lots of water. Machine seems ok now and running on a cycle.
Nov 06, 2010 | Asko Dishwashers
Jul 25, 2009 | Asko D3122XLSS Stainless Steel Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Oct 08, 2008 | Asko Dishwashers
ASKO Overfill protection tripped
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Dec 31, 2007 | Asko 24 in. D3120 Dishwasher
Dishwashers Logo
141 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
