Question about Canon PIXMA iP1800 InkJet Photo Printer
I put a refilled cartridge in and it will not print?
My printer dont print right it skips and i just put a new refill in
It could be due to the refilled cartridge you are inserting in the printer. Refilled cartridges tend to degrade in print quality and cartridge performance.
You can try to clean the cartridge nozzles. On the printer operator panel, on Copy mode, press the Menu button > Tools > Maintenance > Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the print quality has improved.
If that doesn't help, I would suggest you replace your refilled cartridges with new genuine Lexmark cartridges.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Refilled black cartridge 36 on my 5650 won't work
The cartridge is electronically dead. This is a common occurrence from improper refilling. To be correctly refilled it must be done under a vacuum to prevent air from entering the print head, which has likely happened. As ink flows through the print head it acts as coolant in an engine, when air is introduced the print head cannot cool, over heats, and ruins the cartridge. These cartridges are difficult enough for us professionals to refill successfully, my recommendation is to leave it to us, or buy original. A refilled integrated print head cartridge will always continue to read as empty because there is no way to reset the cartridge, the manufactures do this on purpose. Lexmark cartridges in general are designed to only last one cycle anyways, multiple refills is attained only with proper technique.
Feb 02, 2010 | Lexmark X2500 All-In-One Printer
HAD BLACK INK CARTRIDGE REFILLED AND REPLACED , PUT IT BACK INTO HP7550 PRINTER, NOW IT DOES NOT PRINT AT ALL DID NOT PRINT A CALIBARATION PAGE
You usually have to install a DIFFERENT cartridge at first to fool the printer into thinking you changed the cartridge then swap to the refilled one... Their feeble attempt at making sure you don't refill and use the same one.
Oct 27, 2009 | HP PhotoSmart 7550 InkJet Printer
Printer slow after putting in a refilled cartridge
Sounds like the TSR is out on your cartridge. The TSR is the heat sensor for your print head. If the TSR goes out it cannot tell the printer that the temp at the print head is at ok levels. So the printer assumes the print head is really hot and at risk of fusing its nozzles so it prints really slow (the faster the printing the hotter the print head gets). It is possible, but not very likely, that the ink in the cartridge is of such low quality that it is not cooling the print head properly as it flows through the nozzles. Thus the TSR tells the printer to print really slow so you don't burn up nozzles. If you got this cartridge refilled at a store or on-line I would return it and get your money back. I recommend Cartridge World for refills because if this happens to one of their refills they will give you a new refill at no charge.
Oct 15, 2009 | HP PSC 1610v All-in-One Printer
Lexmark X1100 Series won't print in colour after cartridge refill
I have refilled my cartride many times. Sometimes the colour has not worked so I found that if I put the lower end in hot water and made sure all 3 colours came out in the water the printing then worked. It simply was clogged after refilling.
Dec 27, 2008 | Office Equipment & Supplies
HP deskjet 970cxi not printing red
Hello, usually the refilled cartridges doesn't work well.
You can try to fix your problem doing this:
1) Put some boiling water into a cup
2) Put the the cartrigde (print surface) close to the water to receive the steam (not inside the water)
Do this just a couple of minutes.
3) Put it back ther cartridge into the printer
4) Align or clean the cartridges with a printer program
5) Try printing again
If still does'nt work buy original cartridges or due the high cost of them buy a new printer.
Please don't forget to rate this solution! Have a great day!
Oct 07, 2008 | HP DeskJet 3325 InkJet Printer
Refilled Cartridge
How can I Reset Memory For Lexmark X4550
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
It will not print anything
The problem lies with the refilled cartridge. 1.) Try wiping the bottom of the cartridge with a moist paper tower, to clear up any dried ink. 2.) Put cartridge back in and use the "clean nozzle" feature on the fax machine. 3.) If these steps don't work, it is best to take the refilled cartridge back to the place and have them take a look. Sometimes it can be salvaged. WHY: The print-head (bottom part of the cartridge, retangular shaped, where the ink comes out) is blocked, thus the ink isn't able to come through. This is NOT any fault of the ink refilling service, but rather a wear and tear issue with the cartridges. Most refilled cartridges will work perfectly fine and save you a lot of money.
Aug 29, 2006 | Sharp UX B700 Plain Paper Inkjet Fax
Canon PIXMA  iP1800 InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
