Question about Bosch Axxis WFL 2060 Front Load Washer
Noise, vibrations, banging, walking - Bosch Axxis WFL 2060 Front Load Washer
    Genius:
  • Bosch Master
  • 1,474 Answers
Could be burst spring on top..is the drum hanging low?
Posted on Sep 29, 2009
Brother sq9050 walking foot skipping stitches making a banging noise
Do you know the model of walking foot?
Can you post a photo?
Feb 25, 2013 | Sewing Machines
Front loader excessive vibration and walks.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 31, 2011 | LG WM2301HW Front Load Washer
Washer makes loud banging noise on spin cycle and walks across the floor. The drum rotates fine on other cycles and belt seems to be intact
Have you removed the bolts at the back of the machine. they are there to help stop it getting damaged in transit but if left in when in use it vibrates violently and moves a lot read manual and look at back to see if bolts are left in and remove them if so. hope this helps.
Dec 28, 2010 | Samsung WF337AA Front Load Washer
Have ge model WCVH6800J1MV Will be 1 year old in Nov. it bangs and walks across the floor. it also vibrates and makes loud "clicking" noises have had five service repair visits all to no...
had the same problem but 7 or 8 months it started had it replaced and 7 or 8 months on new again same problem, a speed wash which is 36 mins takes 1.5 to 2 hrs
Oct 27, 2010 | GE WBVH6240F Front Load Washer
Electric oven makes an awful vibrating noise when hot
yes it can,i have used double sided sticky tape tp put between the blower houseing and top
May 26, 2010 | Ovens
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
Dryer banging
Check the vibration damper rods. It is detecting an uneven load and stopping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise
The vibrating sound you hear could be due to "water hammer" when the fill valve tries to close against high water line pressure. I had that problem and solved it by putting a small valve in the line to the ice maker and closing it little by little until the vibrating went away. You know, the banging could also be water hammer. It only happens at night when the entire neighborhood is asleep and the water pressure is at its highest. You need to check this out because water hammer can be very destructive to the plumbing and the valve.
Tom
Sep 08, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Bosch Axxis WFL 2060 Front Load Washer Logo
202 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
