Windows explorer has failed, send error then restart!!!! why is it i get a error nearly every 10 mins, then the thing restarts the explorer and i have to re open any web pages or folders i had open?? please help me
yes, i do clear ups regularly and also carry out lots of scans using norton anti-virus, spybot search and destroy, reg-clear and tweak vi!
ive been having lots of problems with vista from day one which has resulted in 3 master reboots as instructed by the tech guys but this problem is a new one and really don't want to have to back everything up again and reboot again! yes, i do clear ups regularly and also carry out lots of scans using norton anti-virus, spybot search and destroy, reg-clear and tweak vi!
You can't post conmments that contain an email address.
this sort of problem is usually caused by one of two things
(1) dirty fuel filter (usually inside fuel tank)
(2) Heat failure of ign system , I use those instant freeze spray cans you buy in auto parts stores to quickly trouble shoot what part is heat failing (coil, module,etc) , run tool to near failure point , squirt part with freeze spray , if it recovers that's the part that's bad (never do this with a chain/cutter tool on !!!!!!)
Explorer is the main "program" of Windows. (the actual windows and folders and icons and such are run by this software program called Explorer which works with other pieces of software to make up the Windows operating system. Having a recurring error with explorer is not a good thing. Take the following steps to restart your explorer -Hit Ctrl-Alt-Del and select Start Task Manager if it doesn't automatically pop up. -Go to the processes tab and make sure explorer.exe is not there, if it is, right click and shut down the process. -Click File-->New Task(Run) -type in explorer and hit enter, this should restart the explorer. -If possible then try running a full virus scan as well as run a scan disk with fix any errors checked
If you cannot get to this process I would recommend backing up all of your important documents and re-installing windows. I hope this helps in some way, thank you.
Windows has recorded a "software-error" in your copy of Windows.
If you clicked "send", Windows will send a problem-description to Microsoft,
so that software-engineers can determine the problem, and recommend some way to fix the problem. Sometimes, the analysis of the problem is done by computers at Microsoft,
and you get some "help" in a few seconds.
Try turning your computer off, and restarting it, to see if the problem persists.
This problem is caused by the Multicore Processor support. Enter the system BIOS and dissable the multicore option. Restart the system and load IE8. Shut down and go back into the BIOS. Then reenable the multicore CPU option and restart. Remenver to save options at the end of each BIOS setup.
this error says that the explorer file of the Operating system has gone corrupted .
first try to restart the computer in safe mode .
once you press the power botton imediately start pressing F8 for 10-12 times it will give you a advance boot option form their try to select safemode with networking check that wether under that condition the computer is working or not
if not then
try to change the boot oder of the computer in bios and change the booting option from hardisck to cd rom .then put the Operating system cd into the computer and them try to click on to repair option while the computer start by doing this the old explorer file will be replace by the new one
Do you close down your applications first before shutting down? If not, give that a shot. If that fails try closing things down in the System Tray (icons by the clock). Try these things first and if that doesn't work, I have a few more things to try.
This is more a software issue than an actual camera problem. May I suggest you repost this in a forum dealing with computers, where there may be someone who has solved this issue.
Do you get an error message which asks you send or dont send? if yes, delete all the temporary files by clicking on tools menu -> internet options -> general tab -> click delete button -> click delete all.
If there is no message before internet restarts, then uninstall internet explorer 7 from 'add/remove programs and try in ie6. if that does not work then remove ie6 from 'add/remove windows components' and restart computer then check internet explorer in 'add/remove windows components' and restart again. It should work.
