Question about Cameras
Lcd screen white and at very bottom can see thin line of what you are looking at
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
SOURCE: thin white static line at top of screen for some
i had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Posted on May 06, 2009
SOURCE: Thin Red Line on LCD TV
I had a similar problem with my LCD screen TV, and to my dismay, my warranty just ran out. A thin red line began to appear on the right side of the screen, and since many online and expert sources pretty much say replace the expensive LCD screen or get a professional to fix it (in which I suspect to be a business plot to get people to go to pricey experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10 minutes. Turn it back on and see if it disappears or improve. (This is the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV (cables, power chords, etc.); you could even try unplugging and replugging the chords/cables. Turn the TV back on and see if the red line disappeared or improve. (This is the one I heard worked for others.)
If the above doesn't work then I'm afraid you do have a bad panel on your screen and will need to call in the experts or get a new TV. I hope this will help. Best Wishes.
Posted on Jul 07, 2009
  • 109 Answers
SOURCE: fuji s700 camera, lcd display screen may be broken
This sound like a broken LCD screen. Does the EVF (Electronic View Finder) still work? If you can live without the LCD, your still in business! If not, replacement by a repair shop is the only other option. If you want to try it yourself, you might check ebay for broken S700's that have a good LCD screen but some other problem. Total disassembly manuals are available online through Google search. One site has every manual for any product you can think of, and if they don't have it, they will find it for you. Digital camera repair is NOT for the faint of heart. Cool nerves,steady hands, and no two year old's around are required. Tiny parts with even tinier electrical connections are the norm. The good thing is that the screen is nowhere near the lens assembly, so dirt ingestion shouldn't be a problem. An illuminated magnifier lamp would also be VERY handy.
Posted on Jul 16, 2009
johnnydiode
  • 647 Answers
SOURCE: only thin white line across my toshiba tv
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 28, 2009
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
White line in the middle of lcd screen
it's the LCD panel. you need to replace it.
Aug 30, 2012 | IBM ThinkPad T43 Notebook
My screen has a white thin verticle line from top to bottom of screen. can this be fixed? Thank you for your time MF
Try to connect an external monitor to the laptop. If the white line is on the external monitor as well then you have a bad video chip in the motherboard, but if the line is gone when using a external monitor then it's the LCD and you should have it replaced.
Mar 02, 2011 | Computers & Internet
There are two very thin lines (pixel thin) that just appeared on the LCD screen. One is in the middle near the bottom, the other is on the lower left side. They are both fixed and are there no mater which...
If these lines are white, then they generally are a line of burnt out pixels. There is no home fix for these and I have yet to see a repairman fix this problem. I have seen on occasion where the line gets longer. Its best to start looking for a new replacement or try to live with it until you can't stand it any more.
May 15, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
Thin and wide white lines on screen
Yes, your screen most likely is going bad, the only other reason for lines and distortion is a loose data cable that runs up the back of the lcd panel on the left side. For the touchpad, go to the control panel > Mouse > look at the top of the window and look for the device properties. open this tab and look for your touchpad listed. Highlight it and click on the settings button. Go through these settings and make sure that tapping is enabled. Even if it is, you may consider updating the drivers for the touchpad.
Jan 18, 2010 | Compaq NC8000 Notebook
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
White screen with thin black line
it is the problem with the lcd itself just call the customer care they will be replace it.
Sep 05, 2007 | Samsung 710V 17" LCD Monitor
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
