Question about Dometic Rooftop RV Air Conditioner
Dometic a/c on fifth wheel with comfort controls
Unit can't keep up when outside temp gets over 80 degrees. The unit then starts to go off and on every 3 or 4 minutes. Also in the furnace mode, the furnace warms the coach 2 or 3 degrees then turns off for a few minutes and starts again. Campers World says a/c unit is operating to all Dometic specs.
  • 332 Answers
First lets address the heating issue. These are not furnaces but are known as "Chill Chasers" and are not designed to "heat" your RV Attempting to use them as a whole coach heater will burn them up in short order.
Your A/C sounds like the coils are freezing up. There is a small probe that is placed into the coils. you can see it from under the unit if you remove the interior cover - a little 1/8" in dia. silver piece flattened on one end to slide between the coil fins with a wire going back to the control box
It may have fallen out
Posted on Mar 08, 2010
I set it for 70 degrees and at 78 degrees to 80 degrees the compressor will turn on for about a minute and turn off. If I move the machine or walk by it the compressor will turn on for a minute.???
there are a couple things you need to rule out. first look at the capacitor in the outside unit. big round cylinder in the compartment above where the copper lines enter the unit out side. if it is round on top its bad. or it could judt be week and need a boot with a hard farf kit. check the compressor to see if its overtly hot or the coils are very dirty restricting the air pull or circulation which will not only keep it from reaching temp but it will burn freon and being short on gas will cause the same thing symptom.
May 19, 2016 | AMERICAN COMFORT ACW300C 10,000 BTU...
We have a3 yr old Goodman CAPF3030B6AA Airconditioner and Furnace. The Air conditioner hasnt worked right all summer. Its 102 degrees outside and we can set the thermostat on 72 degrees and it will be...
A/C units have a design temperature of 90F. Now when the temperature is above 90F they start to have trouble keeping up. Depending on how well your unit is sized for the house, you will notice when the temp is over 90F. I don't know if who ever looked at your unit checked the refrigerant pressures since you said he checked the temps but I assume he did, however, it could possibly need charging.
Aug 05, 2010 | Heating & Cooling
Outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Jul 15, 2009 | La Crosse Radio Controlled Atomic Clock
Dometic refrigerator inconsistent temperature
Yes the clearances on gas absorption frig is critical. Not to say there is not another problem. Is the thermister attached to the frig fins?
Mar 01, 2009 | Dometic RM2852 Refrigerator
Poor cooling fridge
Small slide control inside of the fridge. Think of this as your knob control on house fridge. Slide it up and down the silver coil to adjust temp in the lower unit.
Aug 15, 2008 | Dometic RM2652 Refrigerator
What tempratues should be set on a honywell 4 cycle thermost during the summer months
As a general rule set your t.sat 20 degrees below outside temp. Leave at this setting 30-45 minutes. Move down until comfortable no lower than 10 degrees below outside for 30-45 minutes. Unit should cycle normally. If it runs continuously then raise the t.stat 3 or 4 degrees up. The national average is 75-78. I usually keep mine set at 80 during the day here in Georgia and 74-78 at night...
Jul 03, 2008 | Honeywell Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
175 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
