Question about Epson STYLUS R230 InkJet Photo Printer
How to reset ink printer R230? - Epson STYLUS R230 InkJet Photo Printer
SOURCE: Epson R230 ink & Paper Lamp Blinking
I have an EPSON STYLUS PHOTO R230 series.. INK and WASTE led were both blinking..i restted it already... but the last one.. i can't reset it anymore.. the printer is indicating and saying "Remove foreign Object in the printer" .. what posible damage it has.?. thank you
Posted on Oct 08, 2008
try cleaning your waste pad, then clear counter...... i'm hydrowebb
Posted on Mar 07, 2009
jacklee366
  • 541 Answers
SOURCE: Epson Stylus R230 Ink Canot Recognized
you need to replace the chips on the ciss
Posted on Sep 16, 2009
SOURCE: Installing fake ink for Epson R230
My Epson photo R230 printer memory full, eror my printer has beeb seen two red light signal everytime.
Posted on Oct 04, 2009
SOURCE: both lights are blinking how to reset r230
please help me my printer epson r230 resete softwar need please help me
Posted on Mar 20, 2010
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
You need to reset your printer, because the ink counter is full,
all you need is to download the Epson Adjustment Program And reset the ink counter back to zero, so you can contineu using your printer
Sep 07, 2015 | Epson STYLUS R230 InkJet Photo Printer
What is service require? and how to get this softwere?
There is an ink pad to collect the excess inks inside the printer. It overflows after some time. So, you should replace this inkpad. But sometimes we can reset the settings in software. But you should not do it more than two times. google "Epson R230 reset software".
Jun 05, 2014 | Epson STYLUS R230 InkJet Photo Printer
Service required software
Service required mean waste pad full/almost full. You have to reset waste ink counter. But, you have to replace the pad. or just extend the outlet pipe from head cleaning mechanic to outside of printer.
Browse/googling for R230 resetter/adjusment program. Reset waste ink counter. indoreset.blogspot.com
Sep 30, 2013 | Epson STYLUS R230 InkJet Photo Printer
My printer R230 shows information that one of parts is out of date and needs service
Dear Friend,
It's because of the waste ink pad counter.Goto
http://www.mediafire.com/?9njmgwlxqgj
Download it.
run it.
Select waste ink pad counter reset
click reset ..
it'll work
Mar 10, 2011 | Epson STYLUS R230 InkJet Photo Printer
My printer, epson stylus R230, shows this message ' Parts inside your printer are at the end of their service life. See your printer documentation. ' How can I solve this problem?
You need to reset your printer. Google search for "indoreset for r230", that is the program that you can use to reset your printer. Or you can use the SSC Service Utility, just search for it in the net. You particularly need to reset the waste ink pad counter.
After you reset your printer, check the back of your r230, you will see there a small access cover with a screw. Unscrew it. Take a look inside and you will see a tube connected to the waste ink tank, try to disconnect it from the waste ink tank, carefully pulling it out the access window. Do not force it out completely, you will be able to pull out only about an inch of the tube. When the tube is out, get another tube (silicon or plastic) around 6 inches long would do (12 inches will be fine)that would fit in that tube you've just pulled out, then get an empty plastic bottle with a cover, puncture a hole in the cover and put the other end of the tube in that hole, that plastic bottle will be your new waste ink tank. You are doing all these so you don't have to dismantle your printer to remove and replace the waste ink pads inside.
After doing all these you can now use your printer again. You just need to empty the plastic bottle regularly. And when the time comes to reset your printer again, just use the program again and that's it.
Aug 27, 2010 | Epson STYLUS R230 InkJet Photo Printer
Both lights are blinking how to reset r230
Mar 12, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epsen r230 service requiredParts inside your printer are at the end of their service life. See your printer documentation.
After you reset your printer, check the back of your r230, you will see there a small access cover with a screw. Unscrew it. Take a look inside and you will see a tube connected to the waste ink tank, try to disconnect it from the waste ink tank, carefully pulling it out the access window. Do not force it out completely, you will be able to pull out only about an inch of the tube. When the tube is out, get another tube (silicon or plastic) around 6 inches long would do (12 inches will be fine)that would fit in that tube you've just pulled out, then get an empty plastic bottle with a cover, puncture a hole in the cover and put the other end of the tube in that hole, that plastic bottle will be your new waste ink tank. You are doing all these so you woudn't have to dismantle your printer to remove and replace the waste ink pads inside your printer.
Feb 21, 2010 | Epson STYLUS R230 InkJet Photo Printer
2 red lights blinking
Please see this solution I posted up earlier on another R230 query
Oct 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson STYLUS R230 InkJet Photo Printer Logo
221 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
