Question about Dryers
Trying to take off the blower wheel from the motor. What's the easiest or only way to do it? It's a Kenmore 80 series. Thanks
  • Controlfrk
    Controlfrk May 11, 2010
    The model Number will be necessary to accurately advise you.
  • A Miller May 11, 2010
    My fvriend, you cannot say "easy" and blower wheel in the same sentence. Look for a set screw.
    President:
  • 1,304 Answers
You will need to remove the front of the blower cowel
the then the tension ring
it should then just slide off a d shaft
be prepared it will be tight
Posted on Oct 03, 2009
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
May 20, 2014 | Kenmore 80 Series Heating Element -...
Kenmore dryer 80 series does not heat
May 17, 2014 | Kenmore Dryers
Kenmore 80 series dryer banging
Yes you need to replace the tumbler guiding wheels .should do that soon so you don't ruin the motor and belt
May 03, 2014 | Dryers
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Kenmore 80 series dryer, no heat. blower works
Check to see if the glow bar is coming on first. If it isn't, it is probably the thermal fuse/ cutoff. It is a small white plastic piece on near the motor housing.
http://www.partselect.com/PartDetail.aspx?Inventory=345113&SourceCode=6
or
http://www.partselect.com/PartDetail.aspx?Inventory=344958&SourceCode=6
If it is coming on but not lighting the flame, then you probably need gas coils. They are the two cylinder shape black and white objects attached to the gas valve.
http://www.a-1catalog.com/gasvacokit2.html
Jan 15, 2010 | Kenmore 73952 Gas Dryer
Dryer hums but won't tumble. I can manually turn
most likely motor will need to be replaced if you do repair try to remove blower wheel first you will need a 1/2" rachet and a 7/8 for the motor to hold motor in place you may need to replace also they will lock together some times
Sep 26, 2009 | Kenmore Dryers
Kenmore 80 series dryer no work
bypass door switch , if that doesnt work and you have replaced start switch already. then i would unplug unit remove back panel and look for the blower housing , on the blower wheel housing or to the right should be a white thermostat with 2 wires going to it.round shaped and it mounts to the blower housing by pass it and it should work however dont leave it bypassed. hope this helps
Sep 19, 2009 | Kenmore 60832 / 60834
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
Remove blower wheel
Put a good fittting wrench on the blower nut and hit it with an impact wrench(left handed threads righty lucy). OR do it the tried and true redneck way get a friend to hold a pipe wrench on the pulley inside the dryer, around the back slide a small hammer handle or piece of wood in between two blower blades at 3 o'clock position and slam downwards to pop that mutha loose. The threads are left handed(backwards). That blower does not wanna go easy.
Feb 17, 2009 | Kenmore 63942 Dryer
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
