Question about Canon MultiPASS F50 All-In-One InkJet Printer
Multipass F50 will not print
My printer keeps telling me "wrong cartridge" but I have not put a new cartridge in the printer. It will not print and the alamr light will not go off. How can I fix this? I have tried rebooting the computer and printer, but the problem remains.
  • A Miller May 11, 2010
    We had similar trouble with our multipass.. turned out the power supply was bad. I dont know that this is your trouble ... but keep that in the back of your mind as you progress. We still use the machine as a copier.
Changed ink cartridges, error code Wrong Cartridge, won't print, copy or scan
I had this same problem with my HP All in One. They told me the cartridge was defective, or the sensor was bad. Try a new cartridge first.
Apr 22, 2010 | Canon MultiPASS F50 All-In-One InkJet...
Canon F50 error Wrong Cartidge , now Put in Cartridge
if you ever get this figured out, let me know, my mp730 says the same thing, i had the head cleaned after i got a wrong cartridge error and now i have a put in cartridge error
Jan 26, 2010 | Cannon MULTIPASS C530 Printer
"Wrong Cartridge" - what to try next?
Cleaning won't help this one, you need a new printhead,QY6-0034-010. It only says wrong cartridge when the printhead is burned out.
Aug 11, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Alarm message wrong cartridege
You just need a new printhead, wrong cartridge on a Canon means the printhead is worn out.
Apr 29, 2009 | Canon MultiPASS F50 All-In-One InkJet...
"Wrong cartridge" message.
Wrong cartridge means the printhead has gone bad, no amount of cleaning will help. Sorry about the poor advice, but you just need a new printhead.QY6-0034-010 around $45.00
Apr 20, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Apr 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Wrong cartridge messsage
Hi, Please follow :
1. Reseat F30 / F50 print head 2. The Print Head may need replacing - F50 3. Press ON/OFF switch to reset the multifunction device 4. The F50 may require repair
You can see exactly how to perform these steps with pictures at this link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=6324
Go to this link if you are unable to find the"Wrong Catridge" link
then you need to type "wrong cartridge " in the small search box on the website.
If the website asks you to select
"Category.=Multifunction"
"Product Type =Inkjet"
"Model= Multipass F50"
Cheers
Jun 04, 2008 | Canon MultiPASS F50 All-In-One InkJet...
MultiPASS F50
check the Canon Knowledge base at www.canontechsupport.com, it may be the printhead or unit itself.
Oct 23, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
