Question about Singer Featherweight 132Q Mechanical Sewing Machine
Bobbin won't pick up - Singer Featherweight 132Q Mechanical Sewing Machine
  • 59 Answers
The problem is, your needle so short, adjust your needle bar down, so that the thread of your bobbin will come out.
Posted on Mar 27, 2010
4 Suggested Answers
blaiddwyn
  • 3 Answers
SOURCE: The needle won't pick up the bobbin thread? Seems
I think you mean the shuttle is not picking up the top thread. There are many reasons why this can happen. The best way to find out which is to leave the cover off the bobbin compartment and turn the machine slowly by hand while watching things happen for a few cycles - best to have a piece of material in place as well (but not in your line of sight).
As the needle begins to rise, the top thread should form a loop for the shuttle to pick up. If no loop forms, the needle could be too fat for the thread, the thread could be sticking to the needle, the pick-up arm could be out of time (unlikely), or the thread tension could be wrong (or the machine not threaded correctly).
If a loop forms, but the shuttle does not pick up up, the needle could be bent (take it off and roll it on a flat surface),or in backwards (loop forming opposite to shuttle), or the material (or your manner of feeding it) causing the needle to be deflected away from the shuttle. On some machines, it is also possible to loosen a clamp and move the shuttle closer to the needle, but obviously that is a last resort (unless it has come loose or been forced away).
There are other possibilities, but usually it's the simplest thing. Try changing the needle?
Posted on Jul 28, 2011
  • 980 Answers
SOURCE: won't pick bobbin thread up
If you have changed the needle and made sure it is in the correct way round you may have to retome the machine
Posted on Aug 08, 2011
marigold1m
  • 3 Answers
SOURCE: singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Posted on Nov 28, 2011
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Necchi model 3537 won't pick up bobbin thread
sewvacdoctor.com has a list on their site with helpful free tips. I found this site for you I think will get you on your way. Hope this helps.
Apr 03, 2012 | Necchi 3537 Mechanical Sewing Machine
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Singer sewing machine won't pick up bobbin thread
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
Won't pick bobbin thread up
Aug 04, 2011 | Singer Sewing Machines
Singer Featherweight 132Q Mechanical Sewing Machine Logo
224 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
