Question about HP LaserJet 4p Printer
Paper comes out blank. There is a high pitched
LaserJet 4p. Paper comes out blank. There is a high pitched whining sound that starts when the paper starts feeding until the printing (blank) is done.No other symptom. This started after a paper jam.
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
I've got a 4L that has been an absolute workhorse and it makes a grinding noise here recently and will not print. I hate to replace it as the cartridge lasts about 10 years. I know its about 15 years...
The grinding noise is caused by a cracked motor gear. This is a very common issue on the Laserjet 4L and 4P units. It is a fairly easy repair but you will need to disassemble the printer to get to the drive motor. The gear is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
Feb 16, 2011 | HP LaserJet 4 plus Printer
Printer makes a high pitched whirring sound, paper will not feed and orange light stays on
clear paper feed roller whit wet cloth or alcohol,
1. remove paper tray
2. look for paper feed roller just in bottom of printer.
3. clear it as i said early
4. Enjoy
Good luck!!!
Jan 17, 2011 | HP LaserJet 2200dn Printer
After turning on printer, prints initial "blank" sheet
You can fix this by turning off bidirectional support:
- Right click your printer, select properties
- go to the ports tab, uncheck Enable bidirectional support.
Your printer has to be turned on before printing.
That fixed the extra page printing S1M problem for me.
Oct 11, 2009 | HP LaserJet 4 plus Printer
Hp laserjet 1200 series printer with high pitch nose when in printing process. During this loud noise, the roller turns but the paper is not picked up therefore printing does not occur.
noise is caused by the toner cartridge and paper is not going trough because there is a plastic milar clse to the feed roller that is bent,find it and push it towards the inside of printer (is a black or dark brown plastic mylar)
Aug 24, 2009 | HP LaserJet 1200 Printer
4 in 1 won't feed paper, makes a high pitched whine.
Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer......Now try to Print it should work........
Thanku
Jan 06, 2009 | Lexmark X5495 Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Feb 27, 2008 | HP LaserJet 4p Printer
HP LaserJet 1100
Does it only whine when it paper is passing through it? Does it whine before the paper is fed in and after it's ejected? If so, could possible be the fuser unit. If it only whines when paper is passing through, it may be the paper passing between a worn-out feed roller and separator pad, which are high-mortality items on this model. Can you supply any more details?
May 10, 2007 | HP LaserJet 1100 Printer
HP LaserJet 4p Printer Logo
115 people viewed this question
Seeker5211
Seeker5211
