Question about Samsung HT-Q100 System
Samsung HT TWZ 312 Protection On
Samsung HT TWZ 312 is showing "protection on" and then turns itself off. Does this everytime it is turned on. What is this protection?? And how do I get rid of it.
silly girl
  • 513 Answers
SOURCE: dsp protection
Resetting- taken from the user manual:
Posted on Jan 29, 2006
  • 56 Answers
SOURCE: powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Posted on Jul 02, 2009
  • 56 Answers
SOURCE: samsung ht-q80 won't open tray
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
chipsandnuts
  • 70 Answers
SOURCE: Hello Protection Samsung HT-DS900
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Posted on Jul 03, 2009
cgweatherall
SOURCE: Samsung HT-X40 also shuts off after displaying Protection
You probably have the same problem that myself and several others have had, and let me guess, its outside of the warranty? How good are you with a soldering iron? If you are not afraid to do some soldering you can fix it, check out these instructions that i found:
http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
you will need 474k or .47uf 100v capacitors and a soldering iron, but you can fix it, worked for me.
Posted on Sep 04, 2009
My samsung ht-x30 shuts down after 5 secs and displays protection
Hello
disconnect all the speaker connections, and switch ON the set only, and see whether any protection function energizes or not. If yes, the fault is with the amp itself, and most likely to some damge of components in the output circuit section of the amp. If the amp does not show any protection, when all the speakers are disconnected, make sure that, any one amoung the speakers be the cause of this problem. Connect one after an other and find out which one causes protection circuit to energize. OK.
Dec 28, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
Everytime I turn my on samsung ht-q70 the display screen says protection and the system shuts off. what can i do to get the protection off
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
Jun 21, 2010 | Samsung HT-Q70 Home Theater System System
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Jun 14, 2009 | Samsung HT-DS400 System
Samsung ht-q80 won't open tray
May 24, 2009 | Samsung HT-Q80 System
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
"protection"
I ran across this problem before, the only solution the guy found was resetting the receiver, here''s how to do it:
Jan 30, 2006 | Samsung HT-DB390 System
Dsp protection
Jan 27, 2006 | Samsung HT-DB600 System
Samsung HT-Q100 System Logo
250 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
