Question about Necchi 3537 Mechanical Sewing Machine
Necchi 535 FA
The stitch width setting will no longer make a straight stitch. When set to a straight stitch it continues to make a sloppy zig zag stitch. Are you able to help me with this problem.
  • carlajolan Dec 19, 2007
    Actually oiling the mechanism seemed to eliminate the problem. I will also try tightening the screw. Thanks for your prompt response. Carla
SOURCE: Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Posted on Oct 30, 2007
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
sew dutch
  • 25 Answers
SOURCE: zig zag stitch
If your stitches do not look good on the top side you have a problem with the bottom thread. make sure you have the correct bottom tension: Is the thread under the bobbin tension plate and when you hold the bobbin and case lightly in your hand the tension should be set in a way that there is little resistance , yet still some, when you pull the thread. After you set your bobbin tension, you may have to adjust your top tension to balance. Also make sure the thread comes off of your bobbin the way your manual tells you, clock or counter clock wise.
Make sure your bobbin (plastic) is not sooooo old, buy a new one.
Posted on May 08, 2009
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
White 1521 only zig zag even on straight setting had it cleaned but still only zig zag zig zag on all setting how or can it be fix?
I don't think it needs to be fixed. If you want to zigzag, there are two setting you need to do. One is the stitch length and the other is the stitch width. When you sew a straight stitch, the width is 0. If you want it to zigzag, make the width wider (usually 1, 2, 3, 4, or sometimes 5). I've looked at the manual for this machine and page 21 has some info. There's probably more if you read further. If you don't have a copy, go to singer.com. They have tons of manuals for many brand of machines. Click on the support button and go from there.
Dec 02, 2017 | Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
Why won't my zig-zag zig zag?
Check your stitch width setting if its too low it will just straight stitch.
Jan 21, 2015 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
My machine will not zigzag. Width setting on on1 length setting on widest
You need to take the width setting up to 4 and length down to 2 or less if you want a close zig zag. You may not want it that wide but usually 4 is the maximum width.
There is probably also a stitch selector if your machine has several stitch patterns it can do. I've looked at an image at http://www.stevekraftrepair.com/uploads/resized-P9200750.JPG and it looks to me like the left hand knob on the front of the machine is the stitch selector and is colour coded in with the images on the front panel. I just can't make out which number is the zig zag, it could be the red number 4??? So you would put this dial onto the zig zag, then turn the other dial up to a wider stitch width and I am guessing that the little blue box lower down the case has the reversing button and the stitch length setting.
Usually it pays to turn the width to zero BEFORE you make changes to the stitch selector, most machines seem to like being treated this way, ie engaging cams inside the works.
Also, it is always a good idea to check what foot you have on before you start sewing a swing needle stitch just to make sure that you don't hit the foot with the needle. Some feet are designed for straight stitch only and have a little hole but obviously this is not going to work for a zigzag stitch.
I hope this is of help and that I have understood your problem.
Jun 11, 2011 | Necchi 3537 Mechanical Sewing Machine
Casn I use a double needle on this model?
If you have a zig-zag stitch on your machine, you have the capability of using a twin needle when using a STRAIGHT stitch. The width between the needles is the same as the width for the z-z stitch but you won't be using that stitch. Only the straight stitch.
Aug 22, 2010 | Necchi 6015 Mechanical Sewing Machine
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Need a straight stitich How to make the machine do a straight stich...not reponding to settings
not sure which model you have but you should have a stitch length control and a stitch width control. locate the stitch width control and set it to zero.
if you have done this and the machine continues to zig zag the zig zag mechanism inside the machine is most likely seized up. try lubricating all linkages inside and move the control lever a few times to see if it will free up.
if not you may need a tech to service the machine.
scott.
Jul 28, 2009 | Kenmore Sewing Machines
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Jul 26, 2009 | Necchi Sewing Machines
Necchi 3537 Mechanical Sewing Machine Logo
342 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
