Question about HP Officejet J5780 All-In-One InkJet Printer
It wii not send my Fax Error:350 - HP Officejet J5780 All-In-One InkJet Printer
3 Suggested Answers
Khalsa007
  • 79 Answers
SOURCE: hp photosmart 2610
HI,
u can try to reset the printer.
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
Posted on May 29, 2008
adonscott
  • 106 Answers
SOURCE: wont send fax
Error 350: Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try these steps...
1. Press setup, then go to TOOLS.
2. press okay on TOOLS, then look for RUN FAX TEST. then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Please let me know if the steps that i gave resolve your issue or not. So that i can still go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
Sep 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have an hp officejet pro 8500 fax, scanner, copier and printer. I keep getting an error message 350 when I have repeatedly tried to send a fax. What do I do and what does error 350 mean? Thanks in...
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
Sep 12, 2010 | Computers & Internet
Everytime I send a fax from my samsung sf 370 i get
It can be the other person's fax or there is something wrong with your lines. Conect fax to another line then try again.
Oct 01, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
Error 350
Error 350 means...
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Try this solution...
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved. (To turn off the ECM, simply press the setup button on the pritner, use the right arrow and select advance fax setup on the options. Press ok under advance fax setup. Use the right arrow and select Error Correction Mode. Press ok and select Off.)
*Try sending at a lower transmission speed. (To lower the transmission speed. Press the setup button, go to advance fax setup. under advance fax setup, look for Fax speed. change the fax speed to slow)
After you have done the T/S, try sending a fax again.
Hope this would resolved your issue.
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Wont send fax
Try these steps...
Thank you so much.
adonscott
Jun 29, 2008 | HP Photosmart C7280 Printer
Error Codes
Hi Sir
this is very common error that happens in fax
i am sending a link which has all the things of hp
please follow that arcticle it is going to resolve the issue for you
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpu02549
Jun 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Toshiba e-Studio 350 FAX Communication error
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Mar 20, 2007 | Toshiba e-Studio 350 Copier
HP Officejet J5780 All-In-One InkJet Printer Logo
134 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
