Question about Dell A940 All-In-One InkJet Printer
What is the solution with the Dell Error 50C? I'm running into it with my color cartridge. When I put my old color cartridge it, the message goes away?
Error code 50C
Hi there Error 50c
This is for the Dell 940 but may do for yours aswell.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 07, 2010 | Dell A960 All-In-One InkJet Printer
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
color cartridge.
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
Getting error, "cartridge error" 50C. Dell All-in-one printer, model A940
Hi there Error 50c
Yes this allways happens.
color cartridge.
Oct 13, 2009 | Dell A940 All-In-One InkJet Printer
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
color cartridge.
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Error 50c Using real Dell carts Tried reinstalling drivers still
Hi there Error 50c
Here we go try this out.
color cartridge.
Mar 26, 2009 | Dell A940 All-In-One InkJet Printer
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
color cartridge.
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Printer cartridge error
Hi there Error 50c
There is lots this happens with the dell printers
color cartridge.
Oct 25, 2008 | Dell A940 All-In-One InkJet Printer
DELLA 940 DOES NOT PRINT
Hi there Error 50c
color cartridge.
Jul 20, 2008 | Dell A940 All-In-One InkJet Printer
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
