Question about Hotpoint Aquarius WMA42 Front Load Washer
Door lock flashes
Hi ive got a hotpoint wma42 and the door lock light flashes and doesnt go off and so the machine wont start washing can u give me any ideas what the problems could be
  • 4 more comments
  • lespaul51 Dec 31, 2007
    hi got the same problem WITH A HOTPOINT WMA 40P tried fitting a new interlock switch,still the same, if you set the switch to permanantly on machine works,it seems as if something is not telling the swich to work HELP !!!! please
  • Anonymous Jan 03, 2008
    I have exactly the same problem
  • signman2 Jan 03, 2008
    Have got exactly the same problem
    Got a Aquarius WMA42 with a flashing door lock, so the machine doesnt work
    Any suggestions how to fix it
    Or should I buy a new one
  • Anonymous Mar 15, 2014
    Machine wont go. Flashes DE on the display
  • Anonymous Mar 16, 2014
    door locked light flashs when try to start rince cycle
  • Anonymous Mar 30, 2014
    lock light blinks and won't let washing machine start
    Scholar:
  • 146 Answers
Your switch bracket or switch is either broken or you have no either to or from it. Check your switch first.
Posted on Dec 18, 2007
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint WML540 door lock light flashes and clicks 3 or 4 times then wont do anything? Is it a fault with the lock (which looks easy to replace) or something more serious?
First try unplugging the washer machine for about fifteen minutes or so. Then plug it back in. If the problem still there, then it is the board. It can be fix.
May 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My Hotpoint WML540 wont start wash cycle. The door lock clicks 4 or 5 times then the red door lock light flashes.
This sound like the main control board has blown and this is due to the motor shorting out, if you isolate the power supply and remove the control panel you will be able to remove the pcb/module and inspect it for signs of burning or split tracks if you find this is the case usually it is cheaper to replace the machine than purchase a pcb and motor.
Regards
Ian
Apr 20, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint washing machine (model wma50) will not start due to the door lock light flashing yet the door is closed
common problem on these machine's, you need a new door handle which comes as a full assembley with spring and all attached.
open the door, using star screw driver remove top and bottom screws along with two near the catch.
the doo wil split enough to remove old handle and fit new 1.
Oct 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hi i came home to find the door light flashing on my machine.the machinr had finshed its cycle but not compleatl
Door is likely open. Open and close it and see if it gives a clicking sound to indicate it is closed.
Apr 01, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
Jan 15, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
768 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
