Question about Lexmark X5470 All-In-One InkJet Printer
When I scan, it sometimes does not scan the whole page, just zooms in on a portion of it.
C4485 sometimes only scans part of A4 page, even when there is detail on whole page. Other times scans okay. How do I force it to scan whole page?
Hi
The problem is with the cable connection from main board to the scanner unit. try to reset it. And also do take a cotton swab and little amount of Iso-propane and clean the scanner LEDs on top. And do remember to clean the glass well also try put a little oil to the gears in the bottom of the scanner unit.
DO RATE MY SOLUTION.
Thanks
Jun 29, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Uneven black border showing up on scanned documents
Most scanners scan the whole "bed" not just the document lying on it. Where no part of the document covers the bed usually appears as black.
Normally when scanning you are offered and option whether to scan the whole document or a portion thereof. When previewed, a dotted line appears around the portion the scanner thinks you want, you have to re-arrange that box so that it lies just within the part or the document you require.
Should this not resolve the issue the menu options on
the left hand side of the Xerox web page should guide you to a resolution.
http://www.xeroxscanners.com/en/us/products/DM632/
Mar 31, 2010 | Xerox DocuMate 632 Scanner
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
How do u enlarge on scan mode
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-27
Jul 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Trying to scan and then attach as document an 8.5 x 11 paper
Usually there will be a dashed line that is around the image. Sometimes it will just surround a darker portion of an image, such as the text portion on a white piece of paper. This is common. Use the mouse and aim it at the dashed line and "pull" the lines to the edges of your document, then press accept. This should fix your problem.
Jun 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scanner works correctly sometimes and then only scans a portion
I don't have the exact printer, but I was having the same problem with it. Here's what I did to solve it:
1. Before you start scanning open HP Scan Pro.
2. Click on new scan and it will give you a preview of what is to be scanned.
3. There should be a window you can adjust to scan only a certain area, click on the handles and pull them out to scan the entire page.
4. When you have surrounded desired area, click accept down at the bottom and it should scan the entire page.
Hope this helps!
(I should also probably mention I did this on my mac. It may be a little different for Microsoft users, but this should still work.
Dec 16, 2008 | Office Equipment & Supplies
Scanning documents
try to adjust properly the before scanning option
make it scan the whole page
if this not help tell me so i can help u further
plaese rate this post
Aug 23, 2008 | Canon Pixma MP800 All-In-One InkJet...
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Images appear to be very noisy or grainy
When DIGITAL ZOOM is set to ON in the MODE MENU, the lens can zoom into the Digital Zoom portion of the zoom by pressing the zoom (T) button. When you see the zoom indicator on LCD enter the red portion (towards Tele), the image in the viewfinder will become closer. However, since the D-630 is using the digital portion of the zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image. This is normal when using the DIGITAL ZOOM. The DIGITAL ZOOM can be turned OFF to prevent you from using this portion of the zoom. Locate DIGITAL ZOOM in the Mode Menu and set it to OFF.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Lexmark X5470 All-In-One InkJet Printer Logo
16 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
