Question about HP Officejet 5610 All-In-One InkJet Printer
My scanner says "No scan options" when I try to scan. We have a Mac computer and recently installed 10.6 OS X Snow Leopard. Not sure if this has anything to do with it or not. Thanks for your help!
Driver for mac os 10.7.5
The last Mac OS X version officially supported by that scanner is Mac OS 10.4 Tiger. You *MAY* be able to get it to work under Mac OS 10.5 Leopard or 10.6 Snow Leopard but otherwise there is NO way to get it to work with 10.7, 10.8 or 10.9 since these are Intel only platforms (the scanner software is PowerPC PPC.) Your only option is to run a Windows XP virtual machine inside your Mac and to it that way. I can assist you with that if you like.
Jan 06, 2014 | Minolta Dimage Scan Dual III Film Scanner
Tip
How To Upgrade Mac OS X Tiger 10.4.* to Snow Leopard 10.6.*
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the <a href="http://www.amazon.com/Apple-MC581Z-A-Mac-10-6-3/dp/B002I0JKE2">10.6 Box Set</a>.<br /> <br /> <span style="font-weight: bold;">System Requirements to run Snow Leopard:</span><br /> <ul> <li>Mac computer with an Intel processor</li> <li>1GB of memory</li> <li>5GB of available disk space</li> <li>DVD drive for installation</li></ul> <span style="font-weight: bold;">Snow Leopard Installation Instructions:</span><br /> <ol> <li>Just insert the DVD in the optical drive.</li> <li>Restart your Mac while holding down the C key.</li> <li>You will be guided through the installation procedure and be prompted at one point to choose which install option you want.</li> <li>Once the Snow Leopard install is completed the Mac will restart itself.</li> <li>You will probably be asked to register with Apple upon restart.</li> <li>Enjoy Snow Leopard on your Mac!</li></ol> <b>Q: Can I upgrade directly from Mac OS X 10.4 (Tiger)?</b><br /> <br /> <i>A: Yes. Apple recommends purchasing the Mac Boxed Set for this purpose, which will also update iLife (it is unknown at the time of this writing whether older versions of iLife work with Snow Leopard) and iWork. Also note that while it has been said that the $29 upgrade will work with 10.4, it is not officially supported and may be in violation of the licensing terms.</i><br /> <br /> <b>Q: What happened to the different install options? Can't I do an Archive & Install?</b><br /> <br /> <i>A: Apple has revamped the familiar installation options for Mac OS X. You now have two choices, either a straight upgrade or a clean install. Supposedly if you choose to do a straight upgrade, what actually goes on behind the scenes is what was traditionally known as an Archive & Install.</i><br /> <br /> <b>Q: Is there anything I can do to better prepare myself for the upgrade?</b><br /> <br /> <i>A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in <a href="http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html">Onyx</a>. And finally, it would be wise to get your applications up to date using a program like <a href="http://metaquark.de/appfresh/">AppFresh</a>.</i>
on Feb 16, 2011 | Apple Mac OS X
Canon mf 4018
Hello - Canon does not provide a Mac driver that supports scanning, BUT if you have:
An Intel Mac
and
OS 10.5 (Leopard) or later (including snow leopard, lion, mountain lion and even mavericks)
there IS a fix: Just download the free Vuescan software for Mac, then use it to scan with the MF4018.
Go to: http://www.hamrick.com
Download Vuescan for Mac OS X
Install it, and start the application. It will recognize any scanners attached.
NOTE: If Vuescan asks you to identify your printer, you will not see the MF4018 listed. Choose the MF4010 instead - the 4010 and the 4018 use the same drivers.
Oct 29, 2013 | Computers & Internet
HP Photosmart C3180 All-in-One printer, Scanner, Copier will not scan with Mac OS 10.4. The button flashes for a few seconds, then stops and nothing happens. No image appears on my computer screen.
All lot of those printers came with two separate driver's disc. Make sure that you are installing the correct for the mac and not windows. If you are you can go to the hp website and do a search on there website for the driver for mac operating system.
Apr 25, 2011 | HP Photosmart C3180 All-In-One InkJet...
Hi, Went to the Mac store to upgrade to Snow Leopard and was told my OS was "way too Old to upgrade to Snow Leopard!" Sorry, I'm a numbskull when it comes to these things. Figured as long as...
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the 10.6 Box Set.
  • Mac computer with an Intel processor
  • 1GB of memory
  • 5GB of available disk space
  • DVD drive for installation
  1. Just insert the DVD in the optical drive.
  2. Restart your Mac while holding down the C key.
  3. You will be guided through the installation procedure and be prompted at one point to choose which install option you want.
  4. Once the Snow Leopard install is completed the Mac will restart itself.
  5. You will probably be asked to register with Apple upon restart.
  6. Enjoy Snow Leopard on your Mac!
A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in Onyx. And finally, it would be wise to get your applications up to date using a program like AppFresh.
Lost the scan ability from my printer.
I have this problem most times that I upgrade OSX. I remove the printer in system preferences, download the latest drivers from HP and then re-install. It's working better than ever now with Snow Leopard.
Feb 16, 2010 | HP Photosmart 3310 Printer
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I have a Mac w/Snow Leopard. I cannot get to hp.com\support to download drivers for an Office Jet 7780. The Mac recognizes it as a printer but not as a scanner.
As from this link , the drivers for most HP printers are already built-in to Snow Leopard. Thus, they didn't recommend reinstalling driver from your HP printer CD. Here are some excerpts regarding scanning feature on Snow Leopard from the link: Scanning: The Scanning interface is now built into Snow Leopard and supported with the Apple Image Capture application. Instructions follow. NOTE: HP Scan Pro software (from Mac OS X 10.4, 10.5) is not supported in Snow Leopard. The HP icon for HP Device Manager still in the dock after upgrade is not functional and should be removed. NOTE: Scan support from pushing the Scan button on the printer is not supported with this version of the scan interface built into Snow Leopard. Scan functionality is supported by scanning directly from the computer.
** there are methods on how you can scan on Snow Leopard from the link that I've given above. But I'll paste here Method 3:
Method three: Scan from Print & Fax > Printer browser
  1. From the Apple menu, choose System Preferences .
  2. Click Print & Fax .
  3. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  4. Click the Scan tab, and then click Open Scanner . The Printer Browser window appears.
  5. Click the Scan icon at top right of the toolbar to launch scanning. The scan interface opens. Click Show Details to view settings and options.
Important Gotcha: If the Scan or Print icons do not appear in the Printer Browser window toolbar, you need to delete the current HP printer queue and add a new one, as follows:
  1. Close the Printer Browser window to return to the Print & Fax preference pane. Or, go directly to the System Preferences > Print & Fax pane.
  2. Select your HP printer in the list on the left.
  3. Click the - sign at the bottom of the list to delete the product from the list.
  4. Click the + sign at the bottom of the list to add the product back to the list.
  5. Select your HP printer, and then click Add to create a new print queue. The next time you open thePrinter Browser window, the Print and Scan icons should appear in the toolbar, providing access to Image Capture.
Oct 22, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I cannot find a Canoscan N1220Udriver for Mac OS
Canon has indicated that N1220U will not be supported under Mac OS X 10.6.x (Snow Leopard). The only practical way to continue using the scanner under Snow Leopard is to buy the third party scanner software, VueScan (US$39.99).
Sep 29, 2009 | Canon CanoScan N656U Flatbed Scanner
HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here : http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-41992-1&lc=en&dlc=en&cc=us&product=374572&os=219&lang=en
I just installed the software and am now scanning problem-free.
Oct 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
