Question about Canon PIXMA iP1800 InkJet Photo Printer
It's saying there's a paper jam but inside everything looks fine.
It's saying there's a paper jam and i'm opening it and everything looks fine.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Hi there...i think your printer have something stuck from inside...mybe a piece of paper that you cannot see...
Posted on Mar 03, 2010
There is a paper jam inside the printer and i dont know where
For some paper jam like this it will be better if you blow air inside your printer and make sure everything is clean and not even a small piece of paper is causing the problem. SO better do check again the inside of the printer and use a flashlight for you to see everything.
Feb 07, 2013 | Samsung ML-1660 Monochrome Laser Printer...
I purchased this machine on ebay, and it worked
If you never find any paper in the paper path when it says paper jam, more then likely it is going to be the feed roller...and if the feed rollers are bad, more then likely it will probably need a maintenance kit which will have everything you need to make it run nice and smoothe. Here's what you'll need Click Here!! hope this helps and if so Please mark FixYa...
Jun 25, 2010 | HP Color LaserJet 2600n Printer
Paper jam
look for debris in the feeder very common to see staples, and paper clips in the paper path
Mar 29, 2010 | Canon Office Equipment & Supplies
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Ran out of paper and now makes horrible grinding noise just inside the cover where the paper in the top feeds goes in.
Unplug the printer and open up everything, looking for the paper jam. Use caution when removing the image drums as they are light sensitive. You don't want them exposed to light for more than 2 or 3 minutes. Hopefully you'll find and be able to remove the paper jam and everything will be fine. It seems strange that this problem presented itself right after you ran out of paper...
Aug 12, 2009 | OKI C5150n Led Printer
Hp6210 says "Paper Jam. Clear Jam and then Press OK". There is no paper stuck in it, nothing visible at all.
Open the rear clean out cover and check for a jam. Or the rear clean out cover could just be off like mine was. I was get out of paper message. So I found a the HP help manual that there was a rear clean out. I reached around back and found that i twas off, I popped it back on and it works just fine now.
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper jam - cleared, but still says there's a jam
hi katherine. unplug the printer, wait three minutes and plug it back in. sometimes this will reset everything. if it doesnt, keep looking for a scrap of paper stuck in it somewhere either where it goes in or where it comes out. good luck.
Feb 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper light flashing
What worked for me was to clean the drumunit; take the toner out of the drum unit and clean between the plastic housing and the drum. Dust heaps up and presumably makes the toner rotate more difficult.
I just used a piece of folded paper and blew the rest out..
Bas
Aug 14, 2008 | Office Equipment & Supplies
PAPER JAMMED
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Dec 05, 2007 | Brother IntelliFAX 4100 Laser Fax
Canon PIXMA  iP1800 InkJet Photo Printer Logo
133 people viewed this question
old marine
old marine
