Question about Coleman Powermate Powermate 5000W Generator
Coleman Powermate on/off switch broke off. Is a DIY out of the ?
Coleman Powermate 8hp Model 19G412 Type 1120E2.
The on/off switch broke off when I decided to fire up the generator. Right now it is stuck in the on position and there is no way that I can turn it off without pulling out the spark plug connector. I don't plan on ripping anything apart until I get all my information together.
  • 98 Answers
There is a wire in the back of the control pad...right behind the on\off switch...once it touches the naked body of the gen. it will shut off..
Posted on Oct 11, 2009
Turn off the fuel line and the carb will run out of gas. good thing to do anyway
Posted on Jan 17, 2010
Generator sat unused 2 years. whatshould be done before using for long periods
Change the oil and you will probably have to rebuild the carb. If it has a starting battery, that will need to be replaced as well.
Aug 10, 2014 | Coleman Powermate Powermate 5000W...
Engine quit while running and now no spark.
Does the flywheel magnet still have a strong pull on it?
Mar 20, 2017 | Coleman Powermate Portable Generator...
Hi. I'm trying to help my Dad locate the replacement carburetor for his Coleman PowerMate Model PM0524000, SERIAL# 78661904. Can you help me?
Best way to find a carb is to start with the actual engine model number and type. It should be stamped on engine fan cover. With engine model information, contact local parts dealer for your brand of engine (not Coleman/Powermate, but Briggs, Kohler, Honda, etc.) There are many options for locating parts, including ebay once you have identified brand type model. Good luck
Apr 14, 2011 | Coleman Powermate Powermate 5000W...
NO 20amp 120v power
you probably tripped a circuit breaker. Carefully push in all the circuit breakers, I bet that one of them will give slightly and power will be restored.
Sometimes the 20amp outlet is also a GFI outlet. You may need to reset the outlet itself if so equipped.
May 21, 2010 | Coleman Powermate Powermate 5000W...
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
My Coleman Generator Model 19G412 has a fuel shut-off screw/valve. It was in the off position. I needed to use the generator, but when I tried to turn the screw/valve to the on position, it would not turn....
explore the possibility of removing & replacing the 'petcock'[fuel valve] in the tank.drain tank,remove gas line,unscrew petcock retaining nut at tank & replace.
Oct 12, 2009 | Coleman Powermate Powermate 5000W...
Hard to start
check to see if the spark plug is getting spark, if not it needs to be replaced.
Mar 30, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
1,452 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
