Question about Maytag CWE5800A Electric Double Oven
Oven won't turn off!
I turned the top oven on 350 preheat and walked away. I returned to find the upper broiler on high, the display flashing F2 and beeping. I could not turn the oven off or change the setting. I switched off the breaker. When I switched the breaker back on, the oven returned to high broiler, F2 and beeping. Again, I could not turn off the oven, so I switched off the breaker once more. Several hours later I switched the breaker on, and now the oven works fine. It's been three days, and the oven seems fine. However, I am a foster parent with eight children in the home. Am I going to awaken some night to a house on fire? Thanks, dadclayton@aol.com.
  • 1 more comment
  • angstuart Dec 21, 2007
    I have a double wall electric oven model CWE5800. I turned on the oven and it was working fine for about 20 minutes. All of a sudden the oven started beeping and was flashing an error code F2. I turned off the circuit breaker and turned it back on a few times but kept getting the error message. I have had the circuit off for the last 3 days while I try to find a repair person, but I would like to find out more about this F2 error code. If you have had a similar experience please let me know. angstuart@earthlink.net
  • HarryWismer Jan 18, 2008
    Our Maytag range is a Gemini Gas Range with double ovens. It worked fine for the first three years. Today, I hit one of the buttons and then could not off the oven. After re-setting the breaker, it works fine.
  • euro_dad Nov 19, 2008
    Our Gemini electric smoothtop double oven does not turn off\! The upper oven will not turn off everytime and we have to switch the breaker off to get it to reset. When the ovens are on and cooking the outside of the stove gets too hot to touch. The repair man came and replaced the seals in the lower door and said that was normal for the rubber seal to fall out?
    New Friend:
  • 17 Answers
It probably needed to reset computer/electroics
but i would call customer service for the brand it is a dangerous thing to play with.
make sure there were no recalls also.
Posted on Apr 05, 2017
aborcass
  • 2651 Answers
SOURCE: heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Posted on Mar 25, 2008
SOURCE: F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Feb 07, 2009
  • 523 Answers
SOURCE: Oven takes forever to preheat
check to see if both broil and bake elements/gas works
Posted on May 27, 2010
marka19
  • 1430 Answers
SOURCE: My oven will not preheat and the broiler does not
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 03, 2010
heatman101
  • 43501 Answers
SOURCE: i have a maytag pilotless ignition gas oven. the
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 13, 2010
My Kenmore Model 91195371790 oven Preheat light comes on as soon as you turn oven on and then flashes f2
Over-temp condition due to either oven temperature sensor or ERC (electronic range control).
Testing should be done by a qualified tech to prevent risks to user.
Jan 16, 2015 | Kenmore Ovens
Should my broiler turn on when I am preheating my oven this does not seem right to me and my oven caught on fire last night
Yes the broiler will often turn on to help preheat the oven.
If it caught fire, it is not because of that, but because you have too much run over food in the oven. That is what caught fire. You need to clean it an NOT with the self clean!!
hetaman101
Aug 18, 2010 | Hotpoint Ovens
Jun 03, 2010 | Maytag CWG3100A Gas Single Oven
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Frigidaire FES367ASE Slide in range
Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Maytag CWE5800A Electric Double Oven Logo
242 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
