Question about Microsoft Xbox 360 Console
My xbox 360 will not read any discs - Microsoft Xbox 360 Console
    Genius:
  • 1,093 Answers
This normally is not the DVD drive being faulty, rather the receptos on the back of the DVD drive overheating.
If you can stop the heat build up on the DVD drive you can get back to your games.
You can do this by either sending it back to Microsoft or fixing it yourself with a good Xbox 360 Repair Guide
Posted on Sep 29, 2009
    Sergeant:
    Champion:
  • 378 Answers
YOu will need the dvd drive replaced. We are a listed repair service on this site.
www.videogamerepairservice.com
bestdarngood
  • 3037 Answers
SOURCE: xbox 360
you may need to clean the laser lens, get a dvd cleaner and try that, let me know if that doesn't work
Posted on Mar 18, 2008
  • 35 Answers
SOURCE: Xbox 360 wont read disc
Though i fixed the Disc Read Error myself within an hour but please test the below method at your OWN Risk. Please also note that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourself within an hour. It also provides the money back guarantee in case you are not satisfied. As i fixed my Xbox myself so i thought to share it with you guys.
Posted on Mar 07, 2009
  • 54 Answers
SOURCE: My XBOX 360 elite is not reading discs.
sounds like your Disc Drive has taken a **** I have had the same issue and I had to open it up to make the drive start to spin again
Posted on Mar 29, 2009
  • 441 Answers
SOURCE: xbox 360 not reading discs
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Posted on Nov 17, 2009
rulds2008
  • 3866 Answers
SOURCE: xbox 360 does not read discs
Try using a disc cleaning unit on this if that does not work the drive will need to be replaced around $75 bucks these people at www.videogamerepair.com will do the work for you if you do not know how.\
Thanks I hope this information was Very Helpful
Posted on Dec 13, 2009
Why won't my xbox read the game?
IMO Never Use a cleaning disc for Gaming consoles. Which Xbox 360 do you have? Is it the Older Model or newer one? You can Try Blowing into Your Xbox disc drive. Is your xbox up to date,you can unplug your xbox 360 and from the wall and the Xbox. Wait 25 Mins and Try again.
Jun 13, 2013 | THQ Saints Row 2 for Xbox 360
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
Xbox chewing up discs occasionally
The xbox 360 has a faulty disc drive that will occasionally chew up discs. The reason is that if you move the xbox while its reading a disc it will scratch it to hell but if it does it without movement during reading the disc you need to get a new xbox 360 or send it to microsoft
Aug 16, 2011 | Microsoft Xbox 360 Console
Discs cant be read
If you are getting this it is the sensors on the back of the drive overheating you can use the video Xbox 360 repair guide or send it in
Jul 11, 2010 | Microsoft Xbox 360 Console
Game wont read says put disc in xbox 360 but i am using xbox 360 also it says its a dvd not game just wont let me play no more
If you have recently tried to mod your Xbox 360 then you did not get the drive key installed correctly. Otherwise the laser lens is either dirty/ starting to weaken. You can either replace the laser lens in the disc drive, try to clean it, try the POT tweak or replace the whole disc drive. Keep in mind if you replace the disc drive you will need to swap the PCBs or the drive keys. Hope this helps.
GATpro
May 21, 2010 | Microsoft Fable 2 for Xbox 360
Xbox 360 Console: I've had problem with my Xbox 360 reading my discs...
Disc drive is out, needs replaced, but inorder to replace it you must keep the original drive. You can either order one online and follow these instructions to do it ureself (recommended) or email xbox360repair@palegathon.com for a pricing for repair.
http://www.llamma.com/xbox360/repair/xbox-360-repair.htm
May 18, 2010 | Microsoft Xbox 360 Console
My xbox 360 is not reading any disc. I tried cleaning the dics, I tried new disc and still not reading disc.
If your Xbox 360 is not reading your discs you need to stop the heat build up on the receptors at the back of the dvd drive.
To do this you need an Xbox 360 Repair guide or to send it back
Feb 02, 2010 | Microsoft Xbox 360 Console
My xbox is not reading my discs
xbox wont read any discs and there are no red lights
Dec 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 only pays old games(like pgr3) and not new games(like need for speed shift)
The laser in your XBox 360 is probably going out. When lasers start to fail, the first discs that stop reading are newer, dual layer, discs. Single layer discs will still read. As the laser wears out, single layer DVDs will stop reading but CDs will continue to read. Eventually, everything will stop reading and the laser will die.
You can find lasers for the XBox 360 all over the internet. Installing them isn't easy though.
Oct 03, 2009 | Microsoft Xbox 360 Console
Not reading any discs
My xbox is not reading discs. please help.
Jan 13, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
