Question about RCA R52WM24 52" HDTV Projection Television
R52wm24 - this set has had the convergence board and it's power board replaced. The set gets moved in and out from the wall alot and now getting a green tint to everything. A slight tap or pull on the top corner corrects the color. Is this possibly a connection or ribbon getting lose? tia appreciativly Richard
  • 360 Answers
You need to do a service adjustment on your TV set. You know when the TV is really going bad when you get more red on the screen. A service adjustment will fine tune the set. It takes an hour or two to go through the whole procedure and is matter of hitting the key in sequence and taking and making adjustments with data. Hope this helps.
Posted on Sep 29, 2009
Testimonial: "Thanks for the advise."
  • Richard Klein
    Richard Klein Sep 30, 2009
    With this TV set needs the color cutoff procedure and the white balance adjustment, would solved the green.The green is suppose to be the lowest color.
  • Richard Klein
    Richard Klein Oct 01, 2009
    I believe you can do a picture adjustment by usingthe remote control.
  • RCA Master
  • 8,457 Answers
Tries check outer connections,or HDMI see secure connected,Might fix the prob.
Testimonial: "I have checked cables and have only seen it once since. Hope it's that simple. "
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA Convergence problem TV model #R52WM24..parts?
Thats an easy repair. The flyback develops solder carcks which cause the FL231 fuse to blow and weakens DL231 so the set will lose the convergence options under the on screen menu. You can get the ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com which contains the components and the CD with repair instructions. Its very inexspensive and includes shipping.
Jan 03, 2010 | RCA HD52W59 HDTV Projection Television
Replaced the fuse in RCA R52wm24 and resoldered the flypack now the tv power light turns on blinks three times then turns back off. We had no issues with the tv before today. Any help is greatly...
The fuse blows when there is aproblem with the convergence board - if the TV just had issues with the convergence b4 you soldered and replaced the fuse then the set should not be dead - I would check all plugs especially the 2 flexible (short) cables that jump the (ssb) two boards together. Do you hear the HV trying to start (a little chirp sound near the flyback) If so the set is in shutdown mode if not then power supply problems are usually the cause - check for swelled capacitors in power supply.
Oct 06, 2009 | RCA R52WM24 52" HDTV Projection Television
Getting double image in colors
this is a lost of convegence power. first check to see if you have the convergence option in setup menu. if you do not then i suggest you read the fl231 problem in the tips and trick section. otherwise there a good chance u would have to replace convergence power supply board
Mar 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Convergence problem
convergence problems occur alot in these sets. First question you always ask is the picture bowed in at top and bottom. or even on sides. go into customer menu and go to setup. do you have convegence option. if you do not go read fl231 problem in tips and tricks. this could be simple and inexpensive. However it can also be one of three cuicit boards. Next quesiton if you got convegence option does the autoconvergence work. if not how far does it get. then if that doesnt work does manual convergence of blue and red work do the cross hair move at all. if the do or only move one way. it might be convegence amp if not then might be convergence power board.
Sep 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
R52WM24
I will need you to look on the rear tag and let me know the chassis number as that model was produced with two different chassis numbers ITC222 and the ATC221 chassis was used, But the chassis number will be on the tag on the rear panel. Please reply to this same post and I will help you locate the power supply board.
Aug 13, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv model r52wm24
You most likely need a new convergence power supply board if fl231 keeps blowing thats the most likely cause, also check for shorthed capacitor cp231. If you need a link to get a replacement convergence power supply board, let me know I know where you can get them.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Feb 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Rca r52wm24
When the convergence goes out - and yours sounds like it's completely gone - usually only the conv ICs need to be replaced. If you start "boarding it", you may lose the eeprom that contains all the memory for your particular set.
Get all the "old" boards and parts back in your possession, put them back into your set, then get the ICs and try just replacing them.
You may need to replace fuses as well. Sometimes the resistors also burn up, but that would be painfully obvious, if it had already happened.
Mr Bob
Feb 02, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
272 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
