Question about Coleman Powermate Powermate 5000W Generator
Coleman pm5000 need to know the capasitor voltage
No out put
  • 98 Answers
Check wireing....then brushes...
and finally AVR>..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Posted on Oct 16, 2009
Behringer xenyx 1222fx mixer capasitor
check the capacitor and its value and type. i havent see the equipment but knows about capacitors etc
it usually comes in values like 0.01 2.0022 and so on and higher value like 1 mfd to couple of thousand mfd.you shouls use the same value and the voltage for the replacement one has to be same or more in voltage since higher voltage is no harm but lower voltage will explode or burn in electrical appliances it is used as filters to block spark in the carbon or starting capacitor thich helps to run the motor if it is built to run with a starting capacitor like the one used in water pumps or electrical ceiling fans.
Aug 29, 2012 | Cars & Trucks
I am changing the 3 capasitors on a coleman mach and i need a wiring diagram
You may want to check the PPL parts superstore website as they have a good
parts diagram of the air conditioner. Although I only see one capacitor and it has
two leads.
Mar 01, 2011 | Coleman Mach 15 Air Conditioner
Can i replace a 300uf25v capasitor with a 50v.47uf capasitor in my polaroid tv
No they are not the same, you can go up on the voltage but not down, but you need to be very close or dead on the uf.
Jan 23, 2011 | Polaroid FLM-3201 Television
I have a capasitor on the main board that went out on my 50inch theaterview do i need to have the same capasitor to replace it or can it be close?
Best practice is to replace it with the same value. You do not know how it is being used. The replacement capacitor should have the same voltage rating or higher, that is the only wiggle room you should allow. The uF value is very important. I hope this was of assistance.
May 20, 2010 | Toshiba 55H70 55" Rear Projection...
Found problem but need to know capasitor
Check this page on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ We have repair guides for all three versions of the Dell E173 monitors. If you need any additional information just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
No output voltage for powermate generator
NO. the capacitor resonates with a winding it is in parallel with as part of the voltage regulation.
Recharging a brushless generator can be tricky. I have had success using two 150 watt lamps in series between the running generator and the electric utility power. Search google for this method.
Apr 01, 2010 | Coleman Powermate Premium Plus 6250W...
Compressor trie to start, but don't.
Capacitor is good place to start, once you confirm you have proper voltage getting to the unit.
Jul 20, 2009 | Heating & Cooling
Does anyone know how to repair Genset generators? I have tested the windings, the diodes and capasitor all seem ok. threis not an AVR. when i excite the capasitor the voltage comes up but won't stay, but...
You need to check the exciter circuit for the gen field. If there isn't a voltage regulator, there is going to be a circuit feeding the field. It could even be a 'permanent magnet' rotor inducing the voltage for the stator.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Apr 10, 2009 | Yamaha 2500 Watt Industrial Inverter...
Coleman 5000 generater-no AC output
have you conected the brushes on the right way? the leads are + and -.
you can run it up and use a 12v battery and connect it to the brushes correct polarity, with the othe LEADS removed and taped can shock you and chect the out put it it around 100 120v chech the AVR or brush polarity.
If yours dont have brushes it will have a capasitor that is prob out of spec.
Jan 10, 2009 | Coleman Powermate Powermate 5000W...
Start capasitor
RV dealer or manufacturer. here's a link for coleman below,(RVP) or if Dometic, use dealer or ( dometicusa.com )
http://www.rvcomfort.com/rvp/tech_info/parts_doc_rooftop7000.php
Aug 18, 2008 | Coleman Mach III Air Conditioner
Coleman Powermate Powermate 5000W Generator Logo
97 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
