Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a bush hog finishing mower and i cannot get the old blades off, how do you take them off?
  • 80 Answers
Take a hammer and gently tap the bolts. Then, get a small torch and use a little heat on the bolts this should take care of it.
John
Posted on Sep 29, 2009
Bush hog blades slow down or choke down when cutting grass
sometimes when a belt is wore out it will let the tall grass stop the blades from spinning. put on a new belt and should be good.
May 03, 2016 | Garden
I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Dec 01, 2015 | Kubota T1600H Mower tractor
Pto on our 165 massey furguson will not turn fast enough to run bush hog can anyone trouble shoot?
Hi Lynn:
The speed of the PTO on every tractor I've owned has been directly related to engine RPM and there has been no other way to change it.
Did your bush hog work with it at one time? If it did, what has changed since then? That might give an indication of a possible fix. It may be that the tractor and bush hog are not compatible.
May 14, 2015 | Garden
Is the gear box on an old Woods Bush Hog packed in grease or a heavy weight gear oil and what type is best. How do you prevent leaking
90 weight only. Fill through top until level with side opening. If it is leaking, it has likely blown it's seals. If leak is slow, just keep checking and filling it. If it's just flowing out, it's best to replace the box. No too fun. I've had to do it twice in about 15 years. Hope this helps a little:)
Aug 19, 2010 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
My rdth72 bush hog finish mower - the middle blade is cutting 1 to 2 inches lower tan the outside bladles. why
one of two things the blade spacer in the center is to big or the bering under the center pully is getting bad pull up on the center pulley do you have 2in slop there you go if not center spacer is to long now either your blades are syncronized so the dont hit each other or you have the type that get as close as a hog hair either way your center blade is off set
Apr 24, 2010 | Garden
Bush hog zt2200 that keeps throwing belts
outdoor power equipment.com website will show you the diagram you must type in your model and brand? most of the time the pulleys get bent and out of alignment then the belt twists off once that happens it impossible to reuse old belt ? just make sure it lines up and the tensioner is working?
Aug 27, 2009 | Garden
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
190 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
