Question about Garden
Drive pedal goes all way down- does not make mower move foward or backward
    Problem Solver:
  • 13 Answers
Your drive belt may be broke are you may have some linkage that's came loose take a hard look under your mower
Posted on Sep 29, 2009
Murrym19546 riding mower want move why?
I would believe the mower is ran off a belt and the belt has stretched to the point and needs replacement. Raise the mower up and look under it and see if the drive belt is sloppy or loose.
May 26, 2017 | Cars & Trucks
My mower runs but will not go foward or backward. What happened?
some riding lawn mowers have a lever on transmission to disengage drive system . i am not talking about the shifting lever . i am talking the transmission it self. then check tension on the drive belt
Apr 29, 2017 | Garden
Pedal won't disengage drive
Check the return spring on pedal, may be worn out.
Apr 23, 2016 | Yard Machines Garden
Depress drive pedal forward or reverse, tractor will not move
Assume it's a hydrostatic transmission - most probably the drive belt has come off or broken. Be sure to replace it with a Kevlar belt as changing the belt isn't easy and you don't want to have to repeat the process too soon.
Apr 19, 2014 | Cub Cadet Garden
Snapper rear engine rider won't go into reverse
there is a adjustment at the pedal there is littler rings move some to the side of the pedal you step on if that doesn't help close the knob on top of the fuel tank and stand the mower up on the rear bars(that's what there for) remove the battery if you are going to leave it up move the shifter and make sure that it is sliding all the way over and change the rubber disc that rides on the flat metal disc
Sep 01, 2012 | Ace Hardware Garden
Can anyone help? My Cub Cadet LT1045 won't move (foward/backward).
Hi, check that the drive belt, pulleys and shafts are all ok and that they are actually driving the transmission, hopefully you will see the problem. If the transmission is driving ok and the fwd and reverse lever is functioning as you said, the transmission may have failed. Also check the hydro release lever is functioning. Regards Phil.
Jun 25, 2012 | Cub Cadet Garden
Mower will not move foward or backwards belt ok and turning fan and pully.
then the hydrostatic transmission is shot, look around for a new one or a used one. good luck as a new transmission will cost as much as another mower.
Apr 14, 2011 | Husqvarna Yard Tractor
The mower will not move foward or backwards when in gear and teh brake is released. I did check to make sure that the brake isn't locked. It seems like teh transmission is not engaged. It worked fine in...
Is there a lever or pull device that disengages the drive so you can push the mower? If you can push the mower with the brake off, the trans is not properly engaged.
Is this helpful?
Gary
Feb 28, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Engage problems
it could be in the drive belt take a floor jack jack it up try it in the air & see if it goes into gear e-mail me back at wadembly@aol.com
Jun 07, 2009 | Garden
Polan pro riding mower
sounds like a bad drive belt
Sep 08, 2008 | Poulan Garden
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
