Question about Galaxy Radios DX- 88HL Base CB Radio
No roger beep does the freq counter have anything to do with it?
    Novelist:
  • 500 Answers
The roger beep circuit is next to mic connector and tx/rx cirucuit. the freq counterDISPLAY is on seperate circuit.
Posted on Dec 04, 2009
Galaxy 959 Testing TP3 for AM, LSB, USB with FC-347 or what other freq. counter can be used for this?
An external freq counter will always do a better test then the one on the unit . Do you have an oscilloscope? A function generator will also have a freq counter . Now the ultimate is a spectrum analyzer. you don't need all these but the function generator will work fine.
Jun 23, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxcy DX 66v freq counter and radio slide up and down 3-5 clicks. Not all the time. Nothing I do seems to help
27.385 is perfect for SSB but when you get anything really off freq like if it changes to 27.38334 then it bad but as long as it stays within the 27.385 area as 27.387 to 27.383 you are still considered on freq,If its really that bad send it or take it to a tech and let them adjust it for you.
Apr 20, 2012 | Galaxy Radios DX-66V Base CB Radio
Dx-959 freq counter an channel selector don"t
Hello, please tell me what you were doing before and at the time of change. Were the digit lights recently switched? Please give me a little more information so I can be more specific in my answer. Thank you.
Mar 01, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
The freq counter stays lit at 10.625mnz the claifier knob or the channel selecter will not change the freq counter
This problem, really need to be on a bench to test.. FREE at any good cb shop, to tell you what is wrong.... But most times when a freq counter is not working. Either the crystal is bad, poorly soldered, or its not receiving an input signal. Best way to test is to have a second freq counter external inline using coax.. and check the output of the radio and see if it shows correct or wrong. If it is showing correct they you internal freq counter is messed up. and needs to be check for a bad crystal or solder joints. sometimes even the voltage regulators go bad.. If it is showing a wrong freq on external counter then check the radio's crystal and oscillator circuit. this too can be as simple as a cold solder joint. on the solder side check the small surface mount diode near the PLL, next to the PLL shielded covers. It is normally black these come loose often times too. If you need more help feel free to call or text for more help.
Jan 28, 2011 | Galaxy Radios DX-66V Base CB Radio
When the freq reads 27.225 ch reads ch 26 i can talk to folks and everyboby says it sounds fine don't jump freq or anything just ch select off ???
the freq display can be different from the channel selector display. the crystal in the freqcounter maybe going out or just got out of alignment.... check it with a know accurate frequency counter to determine if its on fequency or not. 000 3174269649
Dec 05, 2010 | Galaxy Radios DX-66V Base CB Radio
I have a new RCI 2995DX . that after 1-2 mounths it go's off frek
Have you herd it off freq? Do you have a freq counter? How do you know that the person that told you it sounds off freq don't have their receive off freq?
if its on a freq counter, and shows not off freq, then the radio is not off freq. There is some other problem.. Or no problem because if it is just some one else saying it, maybe they are just too picky.
Things that could cause your audio to change. If its in your mobile, diving around will make your audio sound different to people. Antenna or feed line problems. If there is a problem with your antenna or feed line, it could make your audio sound bad or off to some one else.
Also, if this unit has been modded, has the clarifier been unlocked? if so that will change your TX freq.
If the unit is new and nothing has been done to it, there should be no reason why it is off freq unless some one has done something to it.
Feb 24, 2010 | Cobra 29 LTD CB Radio
Off freq on ssb TX.
.002 Mhz is really not that much off, try having them tune to your signal When I talked SSB I would have everybody tune to my signal.
Jun 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
My freq counter didnt work on my galaxy dx 959 when i took it out of the box and hooked it up.. what do i do about this and is this common thanks drew
check patch lead with multimeter both centers and outers should read but inner and outer togther should not. try a power meter to make sure you are tx ing at least 1/4 of a watt. try freq counter on another rig. all rigs will run on a counter.
Apr 04, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Not a Galaxy DX-2517
its a mexican kraco clone,lol
Aug 09, 2008 | Galaxy Radios DX-2517 CB Radio
Connex 3300 hp
U mean on sideband? Frequency counter only useful on other than sideband operation. This does not mean the carrier insertion osc. is on frequency. If it needs adjustment, your voice will sound high/ low on transmit. Incoming signals will sound right after adjusting the osc.
May 14, 2008 | Connex 3300 240-Channels Base CB Radio
Galaxy Radios DX- 88HL Base CB Radio Logo
228 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
