Question about Samsung CLP 300 Laser Printer
Hello Have replaced all cartridges and the quality of the print is barely readable, any idea why ? possible solutions thank you!
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
My HP business inkjet 2800 is producing printouts that are very faded and barely readable. The configuration page prints out only in black and white and indicates that the ink cartridges are all nearly...
The only thing to try is to run the cleaning software from 3-7 times, or until print quality is good. Right click the printer icon in the printer folder, select properties, then at the bottom click preferences. Locate maintainence, and run the clean and follow the instructions. If after 7 times the quality doesn't improve, you will have to replace the printheads. As long as the quality improves with each clean, continue to do so until it is acceptable.
Sep 30, 2010 | HP Business InkJet 2800 Printer
The print is readable but blurred, looks smudged and prints pictures blurred too.
Align the print cartridges after installing them to improve print quality. To do this:
1. Load plain paper.
2. Open the Lexmark Solution Center.
3. From the Maintenance tab, click Align to fix blurry edges.
4. Click Print.
Hope that helps.
Sep 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
Poor quality printing - lines through words, some lines very faint, some words barely readable.
Try doing maintenance in the printer settings in control panel , (Nozzle clean, Clean cartridges)
Nov 09, 2009 | Canon PIXMA iP1600 Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Help with HP Photosmart C4340 All-in-One Series - new, barely used Copier quit working Printer prints only in light blue - barely readable
By new and barely used, do you also mean then, still under warranty? If so, return and exchange :-)
Sounds like an ink cartridge issue, though. Try swapping the cartridges out.
Jun 23, 2009 | HP Office Equipment & Supplies
Printer Problem
Your printhead will need cleaning, but don't bother doing it. Your printhead is dead. To request a new one for free from kodak, call 1.800.421.6699. Please rate my solution!
Feb 19, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Samsung CLP 300 Laser Printer Logo
53 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
