Question about Philips Magnavox 51MP392H Rear Projection Television
Picture tube going out?
The picture shrinks in and out all the way back and forth when tv is turned on. Then after a while it goes to normal but the very edges bounce around
  • Philips Master
  • 8,457 Answers
Not ur tube.Ur convergence,dying or be dead.U need a convergence kit.U know how to solder right?Replace what in that kit.Tries these websites.Tv Repair World.com
Posted on Sep 29, 2009
Picture of the tv shrinks to half
Could be a failing power supply. Not surprising after 10 years of use
Mar 22, 2017 | Televison & Video
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from www.TvRepairKits.com
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
It sounds like a loose solder contact in the vertical circuit.
maybe on the vertical ic or some caps in the area.
Feb 24, 2009 | Televison & Video
Shrinking Picture
problem is bad soldier on the vertical IC , this part needs to be resoldier to solve your problem, its a simple job for any tv repairman.
Jan 10, 2009 | Toshiba 36A40 36" TV
The color suddenly turns red for few minutes then goes back normal and goes back and forth intermittently on my hitachi 57f500 tv.
Hello edgarhelen1,
This could be a problem with the Red tube (Grid to Cathode short). I would suggest that you have the tube checked. However if you have a CRT tester you could do this yourself. I any event this sounds like a CRT issue.
Nov 15, 2008 | Televison & Video
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Tv screen goes black for a few seconds
do you get sound while screen does black? what do you mean by "until eventually it has turned black and will not come back"? is it black from the minute you turn the tv on untill you turn it off? if sound is good but picture is black, it may be the resault of a fried monitor tube, in this case replacement will cost alot. if sound is dead also, them it is probobly power supply related issue. get out your DMM and measure the voltages in the power supply. When the screen goes black, is there still regulated B+ going to the circuitry? Do you still have HV? Is the filament of the CRT lit? Does the set still have a raster (you may have temporarily increase the screen setting to see it)? Do you measure any of the flyback derived B+ voltages that go to the video processing, tuner, Vertical Deflection, and other circuitry?
Mar 19, 2006 | Samsung TXD1972 19" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
