dvd burners require alot of space and memory while doing so. try this download the Imageburn software. then instead of choosing burn to disc, select burn to file. this will create a (NTSC) file folder, will have a audio and a video file in it. open image burn and choose >(create image from files and folders) seen in picture below
load the folder you created earlier into this, and make whats called a disc image. once you do this then re-open the image burn and click on (write image to disc) and same as before load the disc image into the window, click burn and there should be a succesful burn!!!
this is a long way to acomplish the same result as burning straight to disc, but this way is less stressful on the system, and almost guarrantees a succesful burn every time!!
