Question about HP OfficeJet 710 InkJet Printer
Hp officejet, printer copier and fax
Won't connect properly and is not lised as a printer on the drop down for adding printers---i did a test print and it wont print in color but it will print in black only---can u help
HP OfficeJet 710 InkJet Printer driver
Posted on Oct 04, 2008
How do i check that HP officejet 4110 all in one printer software is installed in my computer.
Go to Printers and Faxes and right click on the HP OfficeJet 4110 printer,click on Properties then click on Print Test Page. If the Test pageprints correctly then the printer driver is installed correctly.
If the printer is not displayed in Printers ans Faxes or the Print Test Page does not work then install the printer driver.
If you do not have the printer installation CD then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Aug 15, 2011 | HP Officejet 4110 All-In-One InkJet...
I disconnected the hp officejet all-in-one from my computer and later reconnected it. Now it thinks its a fax machine, and won't print from the computer.
it (Hp officejet 4315v series FAX) must be set to default that's why it would not print.The default printer should be the Hp officejet 4315v series,the one without the word fax in the end.
Here's how you do it:
for windows XP operating system
  1. click on the start button on your computer.
  2. click on printers and faxes.If it is not on the start-up list you can click on control panel ,click on printers and faxes or printers and other hardware.
  3. in printers and faxes,it will display all the printers installed on your computer
  4. look for officejet 4315v series or officejet 4300v series then right-click on it's printer icon then left- click on set as default.
  5. try printing from the computer.
for windows vista operating system
  1. click on the start button on the computer
  2. in the search box,type in printers,hit enter key on the keyboard.
  3. in printers,it will display all the printers installed on your computer
If it does not print download the print diagnostic utility from the hp website.It is a helpful tool in diagnosing printing problems.I will provide you the link.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91793-1&lc=en&dlc=en&cc=us&os=228&product=1138346&sw_lang=
Jul 09, 2011 | HP Officejet 4315v All-In-One InkJet...
I have an HP officejet 4215 printer. I cannot get the cartridge (color) 57 to print color! It has been working fine with the smaller cartridge but due to high level of printing, I was told to get 57. I...
If all the the computers connected to this printer via network:
  • Shut them all down except for one.
  • Go to that computer and go to your printer and fax settings
  • Identify the Hp OfficeJet 4515 and right click on the icon and select properties
  • On the General Tab, click on the button that says, "Printing Preferences"
  • Select the "Features" tab and go down to Color Options and check to see that the radial button is green for Print in Color option
  • Underneath that, there is another setting thatsays, "Color Management".
  • Check to see that it is already selected with, "ColorSmart/sRGB or Adobe/rgb
  • Click Ok and return to the Properties
  • Go to Color Management Tab and check to see that it is set to Automatic.
  • Underneath that, you'll see "Color Profiles currently associated with this printer.
  • Look to see that the field is populated, if not click on ADD, and select each color profile that is available
  • Click apply, then OK
  • Shutdown Computer
Turn the printer off, unplug the power from it, wait a couple of minutes, then plug power back to printer, then power it up.
  • Restart the computer you were working with
  • Go to printers and fax options window
  • Select the HP OfficeJet 4515
  • Right click, select properties
  • On General tab, click on, Print Test Page
  • Go to printer to see if printing test page
  • Check to if the Microsoft Windows logo was printed in color
If it is in color, then print the color document you were previously attempting in color.
If it does not print in color, you will have to check your settings on the program that is being used for the document.
Jun 02, 2011 | HP Officejet 4215 All-in-One Color Photo...
Printer Cannot fax n call
When this error appears in your printer check if ink are smeared on the holder where the contact panel is with the cartridge. To fix this issue use the Kleenex(perfume ) added with few drops of water to dampen it and clean off those contact on the holder. You should let the unit sit 24 hours for best results. Before printing anything run aligned thecartridgesa couple times then run clean cartridges a couple of times. Print the test page to look for the condition.
Thank you !!
Jul 15, 2010 | HP Officejet 4355 All-In-One InkJet...
Adding this printer
Hi, perform the steps below if you are usinf Windows XP Operating System:
1. Click on 'Start' button.
2. Open 'Settings' option and Select 'Printer and Faxes' option.
3. Click Add a printer. This launches the Add Printer Wizard.
4. Click Add a local printer.
5. Use the drop down arrow to select the port. Click Next.
6. Select the Manufacturer of your printer and the model. Click Next. If your printer is not listed, click the Have Disk button. You’ll need to locate the manufacturer-supplied drivers on your computer or disk.
7. Type in a name for the printer. This is the name that will appear under the printer icon in the Printers folder. Click Next.
8. If you want to print a test page, click the Print a test page button. Click Next.
9. Click Finish
Oct 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer is not print properly
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq3
Aug 28, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
My printer screen says no connection
disconnected all cables and connected back.
Jan 11, 2009 | HP Officejet 5610 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
HP OfficeJet 710 InkJet Printer Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
