Question about Samsung Digimax L730 Digital Camera
Cant turn on
When charging the light flashes on the charger. left charging overnight but still wont turn on.unplug the camera from the charger push the button but nothing happens
4 Suggested Answers
zohail
  • 1223 Answers
SOURCE: light on my samsung digtal camera charger is flashing orange and
pls checck the batt it is not taking the charge they are weaken and old pls ccheck it
pls rate me fixya for this if u like
Posted on Mar 09, 2009
  • 164 Answers
SOURCE: When I try to charge
Sounds like a busted battery, consider purchasing a replacement.
Posted on Apr 15, 2011
dobhan
  • 105 Answers
SOURCE: I accidentally left my camera
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Posted on Jul 03, 2011
Travel charger wont charge my phone
IF U CONNECT THE BATTERY PROPERLY DEN ONLY THIRD LIGHT BLINKING UP.
Mar 14, 2014 | Sprint Travel Charger PLUS
The charger red light kept blinking while im trying to charge the batteries. after charge the battery overnight, the battery went dead after i took a few photos. does the problem lies in battery or...
Welcome to FixYa.
Red light indicates that the battery is charging. The light will goes off to inform you the charging is complete. Possible that the battery was alreay damaged since you left it charging overnight. Charging time is approximately 5 hours only.
I suggest that you have to replace your battery with a new one.
Feel free to send us your suggestion or comments if this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | Olympus Stylus 790SW Digital Camera
My nikon s203 battery will not charge. When the charger is plugged in, the light is red. When I put the battery in it, the light just flashes red really fast and will not charge. I have left it on...
I just started having the same exact problem. I took it one step further and put the battery on a meter and it checks out at the rated 3.7 volts. Plus, the camera will not turn on. This problem is not covered in the "troubleshooting" guide of the owner's manual.
Mel.
Nov 30, 2010 | Nikon Coolpix S203 Digital Camera
Tomtom 720GO wont turn on
The problem was solved as described in my posting of Aug.15,2009
Aug 15, 2009 | Tomtom GO 720 GPS Receiver
My camera wont charge correctly
I had the exact same problem so I went searching for an answer. Here's what I found and it really did work. I had to do it about 7 times... and I read others had to do it about 20 times. But worked for them as well. Good luck!!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Jul 29, 2009 | Casio Exilim EX-S880 Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Oct 11, 2008 | Samsung Digimax L830 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Casio Exilim EX-Z70
that happened to me too - you need a new battery.
Aug 24, 2007 | Casio Exilim EX-S500 Digital Camera
Samsung Digimax L730 Digital Camera Logo
85 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
