Question about HP 640 Inkjet Fax Machine
Fax machine freezes up
I have a HP 640 fax machine. It freezes up after about a minute. I unplug it and it will start to work again but then freeze again. How do I solve this? The fax machine is only about 2 years old.
leroyal
  • 2120 Answers
SOURCE: HP 640 Fax...can't recieve faxes
Try disconnectiong the handset completely
Posted on Sep 05, 2008
leroyal
  • 2120 Answers
SOURCE: HP 640 fax
Are you plugged into the LINE port?
Posted on Oct 30, 2008
leroyal
  • 2120 Answers
SOURCE: I bought an hp 640
Plug a regular phone into the wall jack to verify that you have a dial tone.
Posted on Nov 13, 2008
newrd1
  • 185 Answers
SOURCE: Hi, is a windows driver for the HP 640 Fax
yes there is
go to HP.com
search for it
Posted on Jan 03, 2010
  • 31 Answers
SOURCE: How to turn off the ringer for HP 640 Fax Machine
Silent mode You can turn the sounds of the HP Fax (including ringing) on and off using the control panel button. You can also set all sounds to turn off on a daily schedule; for example, turn all the sounds off between 8 pm and 8 am. 1. Press Menu repeatedly until BASIC FAX appears and press OK. 2. Silent Mode will display. Press OK. 3. Select On-Daily and press OK. From: 00h To: 23h will display. 4. Enter a start time and an end time and press OK.
Posted on Jul 06, 2010
Using HP 640 fax machine. Sent faxes are O.K., received faxes are blank?
are you sure you have ink in your fax machine. Try just making a copy.
Aug 15, 2014 | HP 640 Inkjet Fax Machine
MY HP FAXNUMER 640 WON'T RECEIVE FAXS AFTER I REPLACED TONER CARTRIDGE
The two aren`t related, you must have pressed a button that changed the `reception mode` to Manual from either `auto` or `tad`
Apr 04, 2012 | HP 640 Inkjet Fax Machine
HP 640 fax only displays bars nothing else will work
while the printer is powered on.....unplug the power module and then press and hold the # 3 button at the same time......while holding the two buttons reconnect the power module......will fix the problem.
Jun 01, 2010 | HP 640 Inkjet Fax Machine
I cant seem to send a fax on my dsl line I have a hp640
DSL is DIGITAL. All fax machines are ANALOG. It won't work reliably.
Jan 07, 2010 | HP 640 Inkjet Fax Machine
I have the same Problem...HP 640 Not sending FAXES
Plug a regular phone into the phone jack and test to be sure you have a dial tone.
Sep 17, 2009 | HP 640 Inkjet Fax Machine
HP 640 fax won't send fax but phone works
Unfortunately wer purchased two new hp office jet 7610 which do not come with cabling and we could not get the fax to work. I spent 3 days on the telephone with hp and British Telecom each of which blamed it on each other. After doing some research on the internet I discovered that hp require a strange cable formant which is called a 'cross-over cable' is required. I bought them from cabling4less.co.uk and the product code is BT-203X. They can be found on their web site www.cabling4less.co.uk The link is: http://www.cabling4less.co.uk/category.php?cat_id=237 This should resolve this frustrating problem.
Jul 23, 2009 | HP 640 Inkjet Fax Machine
HP 640 fax
Oct 30, 2008 | HP 640 Inkjet Fax Machine
You cannot use a four wire cable to connect the fax to the wall. You must use a two wire cable, like the one that came with the machine.  BTW, that means you can't you the EXT port to connect a two line phone or answering machine.
Sep 04, 2008 | HP 640 Inkjet Fax Machine
Not Receiving Faxes
It sounds like you're not set for AUTO RECEIVE. Try unplugging power cord and re-plug in
Aug 13, 2008 | HP 640 Inkjet Fax Machine
Fax Machine freezing
TRY REPLACING SMPS (MAIN FILTER CAPACITOR) --IF NOT SOLVED THEN REPLACE THE MAIN PBA(MAIN BOARD), HAPPY FAXIONG OMNIPRESENT
Apr 13, 2007 | Samsung SF-330 Plain Paper Inkjet Fax
Open Questions:
See all HP 640 Inkjet Fax Machine Questions
HP 640 Inkjet Fax Machine Logo
81 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
