Question about Canon PIXMA MP600 all-In-One InkJet Printer
Pixma MP160 I keep getting the print spooler error message
  • 29 Answers
SOURCE: pixma mp160 error message
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
SOURCE: Canon PIXMA MP160 error 27
My canon pixma mp 160 printer/ scanner is showing E 27, ink absorber is full need help please.
Posted on Nov 06, 2008
arjack
SOURCE: Error message: Service error 5100 on my new Canon MP160 Printer
Error Code.........Description
5000 ...................Home position error
5100 ...................Carriage control error
5200 ...................Head temperature sensor error
5400 ...................Printer temperature sensor error
5600 ...................No cartridge error
5C00 ...................Purging operation error
5200 ...................Scanner cartridge error
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
good luck (^_^)
Posted on Jan 13, 2009
xptareq2000
  • 1447 Answers
SOURCE: canon pixma mp160 ink absorber is full
e75ff09.jpg this the reset wast ink please follow it step by step
Posted on Sep 06, 2009
pineworks
  • 4041 Answers
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Print spooler offline error message when installing drivers from
Go to control panel on windows!Click on administrative tools and click on services!Go to print spooler and start it again!Good Luck!
Apr 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Printer not working properly
MY PIXMA printer will not print after I replaced the ink. The error message says the ink is full. What should I do?
Dec 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Waste tank absorber is almost full ~ message
I've taken this from my manual.
This error message indicates that the ink absorber is nearly full.
The machine has a built-in ink absorber to hold the ink used
during FINE Cartridge cleaning, for example.
You can continue printing by selecting Continue*1
on the display on your camera.
However, because printing is disabled once
the ink absorber becomes completely full
and until the ink absorber is replaced, you
are recommended to contact a Canon
service representative as early as possible.
*1 To resume printing, you can press
[OK] (MP180) / [Black] or [Color] (MP160) on
the machine instead of selecting [Continue].
Feb 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Photo printer
i'm trying to reinstall my canon pixma ip2000 but i keep getting error messages. one of them said that my cartridges are running low on ink.
Dec 27, 2007 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
