Question about iRobot Roomba 560 Robotic Vacuum
My Discovery 4210 Roomba will run normally for about 20 minutes on a smooth, wooden floor. It then begins the following sequence: run forward a few inches, turn in a tight counter-clockwise circle a few revolutions, stop, power off a few seconds, power up, repeat cycle from forward run. The sequence can be repeated seemingly endlessly if I don't turn off the power manually. I've replaced the motor, and led revolution sensor system on the left drive wheel. I've blown the dust out of everywhere. After I let the unit stand and recharge the entire process can be repeated time and again. I've had the unit apart so many times that I've had to use larger screws in some places because the threads in the screw holes have worn out. Anyone have a good, reliable answer to the cause of this behavior?
  • cdigiovanna Oct 16, 2009
    I have totally disassembled the drive wheel assembly and replaced almost everything in it including the led rotation counter source and receiver and the drive motor. I also replaced the drop down switch for that wheel. I do not know what digritz is referring to when he writes of an "optical encoder". I'm guessing he's referring to the led stuff I replaced.
    President:
  • 1,714 Answers
This robot vacuum has a electronic micro processor that controls the unit and tells it how to operate and where to go based on programmed parameters. It's quite a technical marvel. I have dropped a link here for contacting the company tech support line. They will be able to find a replacement part or give you the correct solution to the misbehavior of the machine.
Go here:
http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/ask.php?p_subject=Side%20wheel%20error%20message%20persists%20after%20troubleshooting%20-%20FAQ%20498&prod_lvl1=788&p_prods=788&p_pv=1.788
Posted on Oct 16, 2009
  • 530 Answers
It sound like your Roomba is doing the "Circle Dance". Even though you may think you have thoroughly cleaned it out the problem most likely is the optical encoder. Despite the snug fitting hub cover, dust can still enter. When the optical encoder used to sense wheel motion get even a little dirty the dreaded "Circle Dance" ensues.
Since I am not familiar with your specific model and I am unsure to what extent you have disassembled your Roomba, I can only give general steps.
You need to to gain access to the optical encoder. This means the body needs to be separated. Also any fender attachment and the hub cover. Under that you will find the optical encoder along with the drive belt and wiring for the encoder. A can off compressed used for cleaning keyboards works best because it's clean air unlike what you might get from an air compressor. There is really on need for further dis-assembly from this point. If you need more specific details on a particular area or are unsure about anything please don't hesitate to ask.
Hope this helps.
Tell the truth. You just love taking it apart don't you. :)
Posted on Sep 29, 2009
  • david mcclellan
    david mcclellan Oct 16, 2009
    There are a couple more things I can show and tell you about your Roomba trouble. The first is the show part.
    I have included some pictures that show the location of the optics I was referring to.
    Now the tell part.
    There are two possible solutions to your problem the first I out lined in the prior response. That along with the pictures should allow you to identify and clean the optical encoder sensor. This is an issue because of the sensitivity of this sensor. The real problem for you is even if you get it clean and functioning correctly, the problem is likely to reoccur.
    A more permanent solution is to reduce the sensitivity of the sensor making it less likely to repeat the "Circle Dance" issue.
    This can be done by way of an OSMC update.
    I have added a link to a site that offers this upgrade. It basically allows you to control and modify certain function of your Roomba.
    This site also offers a diagnostic and exchange program.
    However from all that you have already done. You probably have the "I don't care if it's broke or not! I want to take it apart anyway gene". So I also included a link to a site that give detailed instructions on the diagnostic test feature of the Discovery since it's way to much to include here. Please let me know if you need any other help or need anything clarified and I'll do my best. Good luck.
    http://www.protechrobotics.com/proddetai...
    http://mysite.verizon.net/gsplews/Diagno...
  • david mcclellan
    david mcclellan Oct 26, 2009
    Wanted to know how the robot repair was going?
Roomba model 4210 starts and stops after a few minutes only going in short distances and then turning allthough it hit nothing...
Inside this Roomba, the cleaning head module is clogged badly with debris. Open up your Roomba and remove all debris.
Aug 08, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Circles
Do you have it set on "spot"? This causes Roomba to start out in circles, expanding and expanding until a certain time and then returns by going in circles, making smaller circles, until it gets to its starting point.
Oct 21, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba going backwards
I had the same kind of problem with my model 400 today...after starting it and having it go in a circle for 30 seconds or so it would finally run into something and then back up a few inches, turn, then go forward a few inches, then back up a few inches, turn, then go forward a few inches, etc., etc.. I tried cleaning off the four pairs of sensors under the bumper and blowing out various things underneath (by mouth since I didn't have any canned compressed air). It didn't really help. It then occurred to me that I had a leaf blower! I put the Roomba upside down on the grass, put the leaf blower on high, and blew at it from all directions and up close. More dust came out than I thought would. It has been running normally now for the last 45 minutes.
Aug 11, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba wheel -- stuck
I had a similar problem, I just took my Roomba Red apart and put it back together about four times before I fixed it.  In my case it turned out to be a dirty sensor, fixed as described at
http://mysteryroad.blogs.com/photos/roomba_gallery/xintroroomba_3549.html
Before you open it up I recommend following the diagnostic tests to see if its a physical problem (bad motor belt, hair stuck around the wheel) or a sensor problem (dirt makes Roomba think it is stuck when it isn't).  If you follow the diagnostics one of them will move the Roomba wheels while ignoring the sensors; if the wheels move fine then you probably have a sensor problem.
http://www.roombareview.com/swiftracer/roombareddiagnosticsmode.shtml
-- Ben www.benzado.com
Jul 10, 2008 | Roomba Robotic Floor Bagless Vacuum
Repairing stuck wheel/Roomba Discovery
just learning, but sounds like the one that doesn't spin freely is the good one.
The other may have a broken belt.
http://www.roombareview.com/swiftracer/roombabeltreplacement.shtml
Help
Mar 12, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Irobot discovery
It sounds like the battery is shot. These batteries only work for a couple of years and then they won't accept a charge any more. A common mistake people make is recharging them before they need it. This will make the battery "lazy"
Contact the manufacturer for more info.
Dec 09, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
IRobot Roomba Discovery not moving across room.
Sep 26, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
436 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
