Question about Refrigerators
Condensation drains into fridge box - Refrigerators
  • 109 Answers
Check the outlet drain pipe line (from inside to outside tray ), probably it is jammed , clean it with a flexible wire or other tools, hope it will solve your problem. Thanks.
Posted on Sep 29, 2009
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
Bosch Classixx Fridge freezer KGU30604 I keep finding water in the bottom of the fridge but whenever I clear it, it reappears. Both fridge and freezer appear to be working otherwise. The fridge is set to ...
Hi Kloynes,
It could be a problem of LEAKAGE.....Followings steps may help you tackle the problem:
Steps
  1. Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
  2. Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Tips
  • Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
Warnings
  • Use caution with anti-bacterial products. Make sure that any such products cannot flow back into the food compartment.
Things You'll Need
  • Wire hanger
  • Anti-microbial agent such as chlorine bleach, rubbing alcohol or anti-bacterial soap.
Thanks
Sep 03, 2008 | Bosch Refrigerators
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
How do I clean the condensate drain on a Magic Chef fridge mod #ctb1521grw
if not mechanically inclined, call service tech. you could clear by blowing condensed air from drain line outlet, or attempt to disassemble and clear drain from evaporator drain pan
Apr 01, 2015 | Magic Chef Refrigerators
Condensation in fridge
How long does it take for the condensation to build up and freeze the fan?
When was the last time you defrosted the fridge (unplug, open all doors for 12 + hours)?
If you have not defrosted the fridge recently, you may have blockage that is preventing a drain from allowing condensation to escape.
Mar 02, 2014 | GE Refrigerators
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
Water in veggie crisper and meat tray, Moisture build up on glass shelfs
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | Whirlpool Refrigerators
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
Dec 16, 2008 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
