Question about HP Officejet 5610 All-In-One InkJet Printer
No manual with this printer and cannot set up scanner. Says "device documentation for troubleshooting". Please help.
    President:
  • 1,901 Answers
Here are links for the Setup and User Guides:
OfficeJet 5610 Setup Guide
OfficeJet 5610 User Guide
You can also go to OfficeJet Support for additional support information.
Thanks for using Fixya.
Posted on Sep 29, 2009
Trying to scan pictures but its telling me there are no scan options to see device documentation to troubleshoot. How can I fix this?
Try this Scan a document using Paint in Windows XP , follow these steps:
Before you begin, make sure that the product is connected to your computer.
  1. Click Start , point to All Programs , point to Accessories , and then click Paint .
  2. Click File , and then click From Scanner or Camera .
  3. Make any desired setting changes.
  4. Click Scan .Please let me know the results
Dec 20, 2009 | HP Photosmart 3210 Printer
Will not Scan. Gets message..
Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
Nov 07, 2009 | HP Photosmart 3210 Printer
How do i scan the documents on to my computer
be sure that your scanner is connected to your computer using a usb wire. do not try to scan wireless. Also, put the scanner disk back in and you will be all set. just answer the prompts.
Jul 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
I AM TRYING TO SCAN TO THE COMPUTER BUT I CAN'T THIS IS MY FIRST TIME THAT I USE THE SCANNER AND I DON'T HAVE THE MANUAL, COULD YOU PLEASE HELP ME
You need to have "Scan" on your printer.
Insert what you want scanned where you would photo-copy and push "scan". Follow your prompts on screen.
Jan 03, 2009 | HP Officejet 5780 Printer
Scanning a word document Deskjet F4180
Scanning a document is the same as scanning a picture, it must be done from within the document app. In this case I'm assuming you are using Microsoft Word.
Scan a picture and insert it in a document@import url(/Office.css); To do this procedure, your device (a scanner or a digital camera) must be connected to your computer and be TWAIN-compatible. You should also make sure that you have installed the device software that supports TWAIN.
Some devices come with more than one software program. If you are not sure what software is TWAIN-compatible, check the device documentation or contact the manufacturer of the device.
  1. Set up the picture in the scanning device.
  2. On the Insert menu in Microsoft Word, point to Picture, and then click From Scanner or Camera.
  3. If you have more than one device connected to your computer, select the one you want to use under Device.
  4. Do one of the following: If you want to use a lower resolution or you intend for your document to be viewed on the screen, click Web Quality.
  5. If you want to use a higher resolution or you intend for your document to be printed, click Print Quality.
  6. Do one of the following: If you're using a scanner and you want to use predefined settings to scan your picture, click Insert.
    If you're using a scanner and you want to change image settings, or if you're using a camera, click Custom Insert. Then follow the instructions that come with the device you're using.
  7. When the image appears in the document, make any changes you want.
  8. You can use the tools on the Picture toolbar to make changes such as cropping the picture, and adjusting its brightness, contrast, and color.
Note The Insert button might be unavailable when using some scanners because the scanner software doesn't support an automatic scanning. Use the Custom Insert button instead.
Sub HelpPopup(sFile,sID) L_SecurityT1_ErrorMessage="Help can't show you this procedure because the security setting in your browser is set too high" L_SecurityT2_ErrorMessage="or the ActiveX control Ouactrl.ocx didn't install correctly." L_SecurityE1_ErrorMessage="- Select a lower security setting in your browser" L_SecurityE2_ErrorMessage="- If you receive this message after selecting a lower security setting, please see your system" L_SecurityE3_ErrorMessage=" administrator for help troubleshooting the installation of the ActiveX control Ouactrl.ocx" L_SecurityE4_ErrorMessage=" located in the folder you installed Microsoft Office to." sSecurityMSG=L_SecurityT1_ErrorMessage & chr(13) & L_SecurityT2_ErrorMessage & chr(13) & chr(13) & L_SecurityE1_ErrorMessage & chr(13) & L_SecurityE2_ErrorMessage & chr(13) & L_SecurityE3_ErrorMessage & chr(13) & L_SecurityE4_ErrorMessage L_App_DialogTitle="Microsoft Office Help" On Error Resume Next r=oua.HelpPopup(sFile,sID) If Err0 Then Msgbox sSecurityMSG,48,L_App_DialogTitle End Sub
Dec 20, 2008 | HP DeskJet 3930 InkJet Printer
Manual
My printes is saying that it is unable to print . It is asking me to see trouble shooting and routine maintenance chapter.
Feb 11, 2008 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
152 people viewed this question
Seeker5211
Seeker5211
