Question about Muratec MFX-2500 Plain Paper Laser Fax
Muratec MFX 2500 copies have lines
When printing or copying any document, lines (vertical and horizontal) are on copies
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Muratec Master
  • 1,362 Answers
Need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Posted on Dec 26, 2007
Settings on muratec mfx 2010
How can I fix the black paper when I copy in muratec mfx2010 ... I mean when I copying a paper.... the paper I get its all black
Mar 09, 2012 | Office Equipment & Supplies
Can you adjust the edge erase area around the border of the copies printed out on the MFX 1430. I would like to reduce it,because it cuts off some of the letters and numbers
Unless someone has changed it(made it larger)...factory default is 2mm void at the edges and you can't make it any smaller than that.
Nov 28, 2010 | Muratec MFX-1430 Copier
When copying a document the copy comes out all black, what is the poblem??
do you have the users manual??? if not get one at this address
http://www.muratec.com/new/support/manuals-for_muratec0o34534021023994938849.asp then try printing out a list or report of some kind...see if its still all black. If pages printed from memory are ok does the lamp undert the glass come on when you make a copy.???
Sep 14, 2010 | Muratec - MFX-1300 Copier
Muratec mfx 1300>> CAN I reset A "replace
YES....try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT.
Jun 16, 2010 | Muratec - MFX-1300 Copier
Muratec MFX- 1430 Printer
first of all, you can change the toner cartridge at any time. the roller below is probably the transfer roller, which can be cleaned. you may also want to consider that the drum cartridge could be the culprit.
since this is a multi function machine, make sure that the lines are not showing up when you print, or receive a fax. if the lines ONLY show when you copy, then clean the small **** glass under the document feeder, that should be the source.
Apr 01, 2009 | Muratec MFX-1430 Copier
Muretec mfx 1430 streaking through the adf and its not the **** glass. Off the glass looks fine have swamped out the whole feeder twice same problem.
Hello sir; Let's try two things , 1st, make a copy go through by ADF. 2nd, make another copy direct from the glass. if 1st one coming out with streak line that's mean on the left hand side of the plateform have a piece long strip glass need to clean.
if streak line coming out from 2nd copy that's mean you need to replace drum cleaning blade.
Mar 13, 2009 | Muratec MFX-1430 Copier
Muratec mfx-2500
Try unplugging the power cord for 10 seconds, but you might need a technician to access the SERVICE MODE.
Oct 22, 2008 | Muratec MFX-2500 Plain Paper Laser Fax
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Muratec MFX-2500 Plain Paper Laser Fax Logo
191 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Scott Yeoman
Ed
Ed
Andrew Taylor
Andrew Taylor
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
