My Kenmore Elite (Whirlpool) HE3 dryer is no longer producing heat. I've check to make sure the vent hose and it is not clogged. Can you advise if there is a circuit breaker, fuse or replacement required for the heating element? Thank you.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
