Question about Dryers
My kenmore 500series dryer does not dry like it is suppose too, could it be the heating element is going bad.? how do I know
  • 51 Answers
Its not heating element they just go bad. most times it is a vent problem if you have poor drying not the dryer. you can unhook dryer vent and run a load though it a see how it works to make sure vent is the problem just make sure you have a window or door open
Posted on Sep 29, 2009
Kenmore dryer won't dry
If you are not getting any heat at all then I would suggest looking at your thermostats, as one of them may have gone bad and that could have cut power to the heating element. If you do have some heat but things still do not dry well, check your exhaust duct to make sure that it is clear of any obstruction. Also make sure that it is not crimped if you have a flex duct on your dryer.
Jul 24, 2014 | Kenmore Dryers
Kenmore 110.82822102 Electric Dryer runs but no heat.
I think the heating element went bad. Depending on your driers layout, you might have to remove the drum assembly to gain access to the heating element. Once drier drum assembly is removed, check and see if there is 220 volts going to the heating element. If there is, heating element is bad, if no voltage detected, the switch in the control panel is faulty. If you're not comfortable trying to check this out on your next step, I don't blame you. A qualified appliance technician would be the better answer especially working around 220 volts. Hope this works out for you.
Mar 10, 2014 | Kenmore 83142 Electric Dryer
Won't heat up
I don't know for sure but have you checked out you exhaust sometimes it can get full of lint and your lint filter take a dry dryer sheet and wipe it down you hope this helps Merry Christmas
Dec 09, 2017 | Kenmore Dryers
Kenmore gas dryer heats poorly
You either have a heating element going bad or thermostat.
May 24, 2012 | Kenmore Dryers
Drying clothes are cold and not getting dry
Bad heating element or thermal coupling. You need to take back of dryer off, unplug first. Then check with a tester all thermal coupling and heating element. You won't know until dryer is troubleshooted.
Jun 01, 2010 | Kenmore 63942 Dryer
CLOTHES DRYER HEATING ELEMENT
The heating element is SUPPOSED to cycle on and off. That is normal. There is an Internal Bias Thermostat and a Hi-Limit Thermostat that help regulate the internal operating temperature of the dryer. However, if you are experiencing longer dry times, or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases and the heating element will appear to glow brighter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Mar 15, 2010 | Kenmore 64742 Electric Dryer
I have a kenmore dryer that is taking a long time to dry the clothes, i finally discovered that the heating element is only staying on for brief periods. I know the problem is bound to be a limit switch...
the first thing to check is the ducting . when the dryer is running go to the outside of the house and check the air flow make sure it is good and strong if it is not good and strong then there is restricted air flow and this will cause increased drying time.the heating element is suppose to turn on and off.there are several ones inthe dryer the best thing to do is check the resistance on them or just replace them all
Mar 05, 2010 | Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Maytag dryer - no heat
If this is a electric dryer the maine thing that goes bad on them is the heater element . If it is a gas dryer I would check the ignighter.
Feb 24, 2009 | Kenmore Dryers
Dryer heating element cycles on and off every minute or two
It is normal for the dryer heating circuits to cycle on and off. The heating element is not supposed to stay on continuously. What usually causes excessive dry times, and rapid cycling of the heating element is poor ventilation. The following link explains:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention to the paragraph that discusses proper ventilation and how to determine whether or not you have a clog. You could STILL have a malfunctioning hi-limit thermostat or operating thermostat, but I suggest you double the simple things first. It doesn't make since to replace parts if it may be a simple matter of general upkeep. Cleaning the lint trap in not enough to keep the dryer ducting clean. If you've never had your ducting inspected or cleaned, now may be a good time.
Perform the simple test of disconnecting the dryer vent hose and try drying a load. If the dryer performs better, you may have a clog in the vent line where it leaves the dryer to where it exits your home. If the drying results are still the same, inspect the internal air blower to make sure it is not clogged.
NOTE: It is also recommended that you use semi-rigid metal ducting. It is crush resistant, resists kinking & heat, and offers protection against rodent infestation.
I hope this advice leads you in the right direction. Let me know what you discover. If it is not a matter of ventilation, then read the steps on how to determine the whether or not the heating circuits are operating correctly. Let me know if you require additional assistance.
Nov 29, 2008 | Kenmore Dryers
Dryers Logo
93 people viewed this question
Top Dryers Experts
