Question about Bosch Axxis WTA 3510 Electric Dryer
Dyer will not turn on. I have cleaned the heat sensors, the lights go on, it is not over loaded..any thoughts
Check the angle on the vent hose on the back of the machine and the vent flap hoodie thing outside also the vent hose should not exceed 11 feet. I had this problem and replaced the springy plastic covered vent hose with a rigid aluminum one and still have to check from time to time to make shore the hose is clear where it attaches to the machine. The lint from the extreme spin on the axxis washer is very fine and slightly damp it binds like paper mache.
Posted on Jan 21, 2010
Dyer will not heat
Sounds like an open heating element issue. If you have two sensors for internal temps, the chances of both going bad at same time are remote.
Locate the element wiring and disconnect from circuit and do a simple continuity test. Chances are that it is burnt out or open.
Jan 28, 2014 | LG DLE7177 Dryer
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
My Defy 621 electrical stove oven won't heat up
There's probably a faulty connection somewhere. I had that happen a while back when I was in Dyer, IN. I looked for anything that was out of place, but I'm not as smart as I thought I was and had to hire someone (http://www.dbhappliance.com). My advice: call someone. Sorry if that wasn't much help.
Jan 02, 2014 | Kitchen Ranges
Dyer wont spin
Hi - When was the last time the ducting in your home was cleaned and confirmed that it has no debris or build up? Turn the breaker to the unit off for 5-6 minutes. Turn the unit's power back on and try a cycle again. If this does not prove to be successful here are a few possible causes that a technician would be required to check: defective heating element, control board, blower assembly, power supply (240v), high limit thermostat or defective sensor.
Oct 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
I have a whirlpool lgr5634a gas dryer, it heats up but does not seem to heat as high as it should.
possible of lint build up in the discharge vent vaccum/clean out first. next ensure the filter trap is clean and the below area is in the discharge area is cleaned out. also the sensor on the inside of the drum could be coated with sooftner causing the sensor that automaticly tells the dryer when top stop/ amount of heat to produce could be coated use isopropel alchol to clean and check after 10 minutes if the dyer is functioning properly at this time.
Mar 05, 2011 | Whirlpool LGR5634L Gas Dryer
Dyer will heat for a short time then blow lukewarm air and then cool air.
All dryers made within the last decade have a noister sensor that senses the heat flow. If the exhaust vent is clogged up with any lint the sensor will shut the burner completely off. Check the vents thoroughly from the dryer to the outlet oat the wall. If clogged ajnd cleaned it will operate correctly again. If not the sensor is at fault
May 17, 2010 | Whirlpool WGD5500S Dryer
I have a kenmore elite he3 dyer it does everything it is supposed to but heat. pulled the front cover off unpluged the dyer and cleaned the inside, started the dryer again and the heating element came on...
A possible fix, which sounds completely absurd is to reset the circuit breaker. If you visually examine the breaker it will not appear to net resetting. This is because only half the breaker has been blown. You will not see this visibly and my husband thought I lost my mind and spent several hours troubleshooting before he would listen to my solution. We have only had to do this once in the six years of ownership. Hope this helps
Jan 18, 2009 | Kenmore 82822 Electric Dryer
Dyer malfunctions
Clean off the two metal bar inside the drum, near the lint filter. (these are the moisture sensors, which can become coated with fabric softener sheet residue, preventing the dryer from "seeing" that the clothes are still wet)
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Tumble dyer
first, you should check the exhaust system, make sure every inch of it is clean on the inside. if it is clogged, there is sensors that turn off your heating element as a safety measure. if this is clean, there is 2 heat sensors, one of them probably needs replaced.
Oct 28, 2008 | Dryers
Bosch Axxis WTA 3510 Electric Dryer Logo
143 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
