Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Freezer door does not seal tightly and will open when refrigerator door is shut
  • 109 Answers
Change the magnetic gasket from a good service center or you can change it yourself. Thanks.
Posted on Sep 29, 2009
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
When i close the freezer or refrigerator doors the refrigerator makes a strange noise. like something is working hard to create a vacuum in order to shut tight???
could be just vacuum caused by temp diference if you shut hear noise then try to open quickly but is stuck shut try pushing seal so it breaks from surface. if door opens easy then this is normal on some makes. also be aware if frot free when you close door fan comes on. May be getting noisy bearings.
Sep 01, 2010 | Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator side not sealing tightly when shut.
Sounds like you may need a new magnetic seal. It is worth the money to fix it, saving electric and your food items.
Good Luck
Aug 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer door pops open
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bosch kvg28323gb fridgefreezer
Well, there made to seal to keep the air in. Did you try a little DW 40?
Dec 13, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
