Question about Canon PIXMA MX310 All-In-One Printer
Says there is a paper jam but have checked and there is no paper jam paper goes in 1/3 of the way and then stops and paper jam icon comes up on the computer....son has paper he needs printed by tomorrow...
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
My HP Laser jet P1006 will not print. when I click printer and faxes on my computer it is showing me that I have a paper jam. I have checked the printer and this is not the case. The computer has allowed...
1) open printers and faxes.... right click on the printer icon... click on pause printing... and then click on cancel documents.... when that is cleared... right click and delet the printer icon while u have the usb cable unplugged... once that is gone... plug in the usb cable... wait for few seconds and then try to print....
2) if u are not able to delete the printer icon by following the above step... click on start and then run... type in services.msc and hit ok.... in the services window stop the service called print spooler and then start it again.... and then follow the step 1... it should get deleted
3) even after completing the step 1 and when u try printing... if u r getting paper jam error message then thoroughly look for any jammed paper... even a small piece of paper will cause this problem... so check out thoroughly... and if u dont find any... reset the printer by following the below link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01174212&tmp_task=useCategory&lc=en&dlc=en&cc=us&product=3435684&lang=en
you can also go through the following document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01179923&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3435684
Mar 18, 2011 | HP LASERJET P1006 Printer
Error during 1st install of paper
konica minolta magicolor 1680mf service call 0094
Help me
May 30, 2010 | Konica Minolta magicolor 1680MF -...
EPSON DX5000 will not feed paper. It goes in about 1 inch then stops. No jam warning until it appears to finish printing. When I renmove the paper there appears to be a small dent in the leading edge of...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Epson Stylus DX5050 All-In-One InkJet...
What does E 2 mean on Xerox XD 100
PAPER JAM PROBLEM
The Main PWB sensed that a paper jam
exists within the paper path.
E2 Status Code (Without SDF) RAP
The Main PWB sensed a tray misfeed or a paper jam in the paper path.
Initial Actions
• Switch off the power and clear any document jam.
• Check for any obstructions in the paper path.
Procedure
Switch on the power. Enter diagnostic code 30-1.
Open then close the Fuser Gate to actuate and deactuate the Fuser Jam Sensor Q3 while
observing the Paper Jam lamp. The Paper Jam lamp comes on and goes off.
Y N
Go toFlag 2 and check the wires for an open or short circuit.
Manually actuate and deactuate the Paper Feed Sensor Q1 while observing the Toner Cartridge
lamp.
The Toner Cartridge lamp comes on and goes off.
Y N
Go to Flag 1 and check for an open circuit.
Place a piece of paper above the Fuser Gate and use the Manual Exit Knob move the paper
across the Exit Sensor Q4 while observing the Drum Cartridge Lamp.
The Drum Cartridge lamp turns on and off.
Y N
Go to Flag 3 and check for an open wire.
Manually actuate and deactuate Bypass Feed Sensor Q2 while observing the Auto exposure
lamp.
The Auto exposure LED comes on and goes off.
Y N
Go to Flag 4 and check for an open circuit.
Press the Clear button. Enter diagnostic code 6-2. Press the Start button. The Registration
Roll Solenoid can be heard switching on and switching off.
Y N
Press the Clear button. There is +24 VDC measured between CN103-1 and GND.
Y N
Replace the Main PWB PL 7.1.
Go to Flag 5 and check the wires for an open circuit. If the wires are good, replace the
Registration Roll Solenoid SOL3.
Press the Stop button. Paper jams in the fuser.
Y N
Check the following:
• Ensure that the paper tray guide is set to the correct width of the copy paper.
• Inspect the paper path from this tray and the paper registration area for an obstruction
such as a burr.
• Inspect the Registration Roll, PL 5.1 and the Pinch Roll, PL 1.4 for contamination
and wear. Clean (with Film Remover only) or replace as required.
Apr 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
The printer jam red icon never stops blinkin
> turn off the printer
> check for obstructions / torn paper
> disconnect the printer from the computer
> turn the printer back on
> if issue still persists, the printer needs service, contact the vendor
Jan 02, 2008 | Epson Stylus C88 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
104 people viewed this question
old marine
old marine
